Author Topic: Cross Tube Brake pedal assay and brake line clips  (Read 2397 times)
« on: May 11, 2015, 05:39:52 AM »
All,
 If someone could post pictures of the cross tube assembly I would appreciate it. I am specifically looking for the washer orientation.
 Also any tricks to the brake line clips? Been wrenching my whole life pretty much and these pesky things have me scratching my head.  :(
Re: Cross Tube Brake pedal assay and brake line clips
« Reply #1 on: May 11, 2015, 03:15:06 PM »
On the cross tube...I can probably snap a photo tonight after work.
Brake line clips...There are a number of clips in a variety of locations.  What part of the brake lines are you working on?
« Reply #2 on: May 11, 2015, 05:37:47 PM »
Thanks Tim, I am talking about the clips that attach the run along the frame rail, strange little buggers. The pic shows one just above the forward leaf support
« Last Edit: May 11, 2015, 05:40:00 PM by Kirkski »
« Reply #3 on: May 11, 2015, 08:09:45 PM »
Ah yes...those clips.  They are evil little bastards.  In a perfect world, I believe they belong like your photo shows, but I can't get mine to hold the line.  So, I pull the little tab far enough away from the frame and slip the brake line in to the large loop.
Here is a photo of the cross tube on my green Willys...
The clutch side is fairly self explanatory.    From the frame...inward.
-Cotter Pin
-Large Washer
-Brake arm
-Large Washer
-Bracket Support (to Master Cylinder)
-Cotter Pin
« Reply #4 on: May 11, 2015, 08:55:55 PM »
Perfect shot Tim, thank you so much!
