Author Topic: Crank starting....  (Read 2981 times)
Crank starting....
« on: February 27, 2015, 04:05:44 PM »
When we put the engine together we installed a front crankshaft nut that would accept a hand crank..
I got a one piece hand crank off ebay about a year ago, but it is too short to reach through the bumper, but turns the engine fine if installed under the bumper..
So I need to lengthen it, and I'd like to make it two piece so I can stow it in the tool box...
I thought I'd cut it in two...find a 3/4" drive socket extension, 6" or 8", cut it in half or as needed, weld the ends on the crank sections and I could then fit the two pieces together when needed....
The crank is really handy for setting the timing and setting valves, and who knows I may even need it to start one day...
Ideas or better suggestions?
That is a 1/2" drive extension in the picture...the crank is 3/4" diameter....
« Last Edit: February 27, 2015, 04:06:40 PM by 1955CJ-5 »
Re: Crank starting....
« Reply #1 on: March 09, 2015, 04:33:04 PM »
I think that is a great idea!  I have thought about getting a crank for mine also but have never pulled the trigger.
« Reply #2 on: March 09, 2015, 04:56:15 PM »
There was a little glitch.....the large end of the 3/4 extension was too large for the 1" hole in the bumper...my idea now is to get a couple 3/4 socket adapters, say 1/2 to 3/4 and a 3/4 to 1/2, knock the 1/2 fitting off the one and then weld them to the two parts of the hand crank so the two 3/4 ends will mate...........
These are not the right size but you get the idea....
« Last Edit: March 09, 2015, 05:00:29 PM by 1955CJ-5 »
« Reply #3 on: March 09, 2015, 05:25:17 PM »
Very cool.
How about cutting the original right after the handle bends�maybe at 20 to 21�.
Weld the extension to the handle portion�then shape the straight piece to fit in the extension end of the handle.
This idea may not fit in the box though.
Edit::::: Never mind.� Just measured to the pulley.� 22" to the face.� I get it now.
How about staying with the same idea, but picking up, then scabbing in a length of 3/4" round stock steel?
2nd Edit::::Never mind.  Now it's probably too long to fit in the tool box.  How about you stick with you idea and I shut my trap?
« Last Edit: March 09, 2015, 05:33:50 PM by athawk11 »
« Reply #4 on: March 09, 2015, 07:35:49 PM »
That'll sure beat my ghetto set up:
