Author Topic: T/C output shaft end play  (Read 1946 times)
« on: October 28, 2014, 08:32:24 PM »
OK....It was suggested that I check the output shaft end play in the attempt to isolate my high pitched noise....
So this is how I did it, while the T/C is still in the jeep...
I gave the shaft a couple of good raps with a copper faced knock-off hammer (wire wheel type)
I set up my new  :) dial gauge and then pried behind the nut to move the shaft rearward...
I get .004.....004 to .008 is the range....
I have one more shim, it's .002.......
Should I install the shim, or call it good?
Offline ZekeD
Re: T/C output shaft end play
« Reply #1 on: November 02, 2014, 07:16:28 PM »
Nice gauge...... (envy).
Zeke
« Reply #2 on: November 03, 2014, 02:15:32 PM »
What your measuring is the end play between two taper bearings. .004" is good and you don't need to change it. The front output shaft is supported by a ball bearing and doesn't need measuring the end play.
« Reply #3 on: November 03, 2014, 03:17:06 PM »
OK thanks Carl....I was concerned about getting an accurate measurement with it assembled and still in the jeep...but I tried it 3 or 4 times and it was the same each time..
« Last Edit: November 03, 2014, 03:18:08 PM by 1955CJ-5 »
