Author Topic: Clutch Release Bearing Spring  (Read 3031 times)
« on: August 04, 2014, 12:39:43 PM »
This is the small spring that attaches the bearing retainer to the throw out bearing on the front of the T-90.� �It helps pull the bearing off the clutch fingers when releasing the clutch pedal.
This is a really small and insubstantial spring.
Has anyone ever had one break?� I haven't, but I feel it's only a matter of time.� Should this be a 'Must Have' in a Willys roadside repair parts kit?
Re: Clutch Release Bearing Spring
« Reply #1 on: August 04, 2014, 01:09:12 PM »
Good question Tim. I've often wondered the same thing. I've never broken one but it does seem like a really inferior piece of hardware for the continuous workload it must endure.
« Reply #2 on: August 04, 2014, 02:02:23 PM »
I've not broken one, and the one on the 51 was intact when I took it apart..in fact I think I re-used it as it was a little different that the repro replacement.
I wonder if you'd even notice if it broke....except the clutch yoke may come off the throw-out slider...
« Reply #3 on: August 04, 2014, 03:57:12 PM »
Tim, I wondered the same thing last week when I was installing my transmission.  I scoured my spare parts bin at my house and my father's shop and couldn't find a suitable replacement spring so I ended up using my original.
As to whether or not you would notice if it broke, I would don't know.  The throwout bearing takes quite a bit of pressure to push against and engage the pressure plate fingers.  These fingers would probably push the bearing back out and off of them when released and everything might function correctly.  However.........
That spring also helps prevent the sleeve from rotating and keeps pressure on the shift fork against the pivot stud.  In a worst case scenerio, I think it would be POSSIBLE (although not likely), that without that tension the fork could slide off of the throwout bearing sleeve and linkage and end up beating around the clutch/pressure plate like a blender! :o  It seems like a perfect example of Murphy's Law that as hard as that fork is to install it would only take a stiff wind to come off.  It felt like to took four hands and a midget to get mine installed this weekend......
Just my humple opinion!  Someone with more experience should chime in...
« Reply #4 on: August 04, 2014, 08:21:37 PM »
I appreciate the feedback fellas.� Keep it coming.�
While trying to be proactive, I bought a reproduction spring from Walcks.� When comparing it to the unbroken original, the new stuff is a bit longer.� I put it on anyway and found it to be a bit wimpy.� The original is stretched more and really pulls that bearing back with a snap.� The repro pulls it back, but with much less fortitude.�
This is what got me to thinking.� I like the power of the original, but would that cause it to have a shorter life?� But then...I've never had one break.� Thus, my inquiry.
« Reply #5 on: August 04, 2014, 09:09:15 PM »
I think I ran into the same thing....I didn't like the repro and re-used the original...
I ran across two types of throw-out sleeve..imagine that...one had the ear for the spring much further from the base of the sleeve....maybe the repro spring is meant for the one with the more distant ear?
