Author Topic: Transfer case breather/vent...  (Read 3304 times)
« on: July 08, 2014, 01:09:48 PM »
I have a small leak, just enough to keep the skid plate well lubed and the transfer case side from rusting, but it seems to be coming from the top of the TC....There is no noticeable leakage from the yoke seals or shifter seals yet the oil manages to accumulate over time on the underside of the body....for yet more rust protection...
Is there a check valve or ball valve in the breather that keeps oil from getting out?  I cleaned mine pretty thoroughly but I did not take it apart...
Re: Transfer case breather/vent...
« Reply #1 on: July 08, 2014, 02:11:06 PM »
OK, I investigated further....the breather is the type that has a   bottle cap sort of cap, with multiple little fingers that curve over and around the vent tube, so the cap most likely has never been off...
But now I'm pretty sure the leak is from the actuator/shift shaft on the overdrive unit.....there was a fair size puddle on the top of the TC, and drops on the shift shaft, along with lots of that black residue that wearing aluminum makes...I now wonder if something is wrong in the OD? Better call Herm....
« Reply #2 on: July 08, 2014, 04:09:28 PM »
I have the same type of vent on my t/c.  I just tore it apart this weekend and I didn't see any type of checkball in the vent tube either.
« Reply #3 on: July 08, 2014, 05:28:15 PM »
Thanks Mark..
The pictures I've seen of others show a vent with a cap and a cotter pin loosely holding it in place..
But inside there were a couple offset baffles....is that what your's is like? Just curious really, I don't plan on taking it apart now....
« Reply #4 on: July 08, 2014, 07:57:54 PM »
I have a spare D-18 in the garage of unknown origin (aside from being pulled out of the World Famous Doodlebug last winter).
The breather is marked "S-W" on the cap and has the offset baffles.
« Reply #5 on: July 08, 2014, 09:22:58 PM »
My breather is the same as described by Ryan.
I did bend the tabs back, pulled the cap, and did a thorough cleaning.  I was willing to do whatever it takes to reduce potential leaks.
« Reply #6 on: July 08, 2014, 10:24:07 PM »
That is what I have....I remember the S-W now having seen yours....I cleaned mine, the cap is free, I'm sure I hosed it out with brake cleaner...I might be able to get it off now but haven't tried...
I did read on another forum where a plugged breather was causing the TC oil (when heated while driving) to be forced into the transmission, thus overfilling it and then causing a leak through the front bearing and into the bell housing.....
