Author Topic: Saginaw steering pickle  (Read 2642 times)
Offline Tucker
« on: June 16, 2014, 11:08:33 PM »
I've got an issue with my Saginaw setup.
My project was in partial upgrade mode when I bought it.� The original owner had added in a Saginaw manual steering box, which is great, but it was hooked up to a hideous Grant steering wheel that just doesn't work for me.� I'm going back to a stock steering wheel (found an original on eBay), but I want the Saginaw box to stay.� I can't for the life of me find a steering shaft that works with the stock steering wheel.
For those of you who have done this before (added a Saginaw box but kept the stock wheel), what did you do for a steering shaft?� I can't find one the right size.� (I measured mine and believe the stock wheel has a 13/16"-36 spline hole in it--PLEASE correct me if I'm wrong).
Do I simply need to buy a stock worm gear shaft and cut off the worm gear part of it?
Thanks for any help you can provide.
Tucker
« Last Edit: June 16, 2014, 11:09:42 PM by 4x4Dad »
Re: Saginaw steering pickle
« Reply #1 on: June 21, 2014, 01:13:01 PM »
You'll need a column from a '72-75 CJ5 They use the same steering wheel and the column looks the same, but the bottom has a u-joint for the steering shaft.
Offline Bill04SD
« Reply #2 on: June 21, 2014, 06:38:38 PM »
Yes, you can also use a stock column with the worm cut off.  Requires adding a lower bushing or bearing and then the u-joint on the end.  Advance Adapters should have details on their tech site but you can probably source the parts cheaper elsewhere.
Offline Tucker
« Reply #3 on: July 03, 2014, 11:50:21 PM »
Thanks, guys.� (Sorry for the late reply--been camping in the beautiful boonies of the Pacific Northwest for the last week and a half.)
« Last Edit: July 03, 2014, 11:50:49 PM by 4x4Dad »
