Hi Randy,
I installed an Airtex on the Whitey project.� I have the rebuild kit from the Classic Preservations folks.� I plan to rebuild the original, then install it on my OD Willys.� �Just not a huge priority right now.� By the way, thanks again for that link.
The Airtex is a reasonably priced option for a decent backup.� It has the same vacuum and fuel hook ups as the original, so it would've pretty easy to install while in the field.� A single action pump would also work in a crunch, but you would also want to have provisions to close off your existing vacuum lines.�
I think it was just a bad run of luck on that FCT trip last year.� I believe it was Jpet that had two different pumps installed while on the same trail. Both were brand new after market single action pumps.� Crazy.
