Author Topic: Original side steps  (Read 4466 times)
Original side steps
« on: June 11, 2014, 07:52:23 PM »
I got lucky and found a really nice pair of side steps for the '51..
Does anyone have a picture of or knowledge of the way the rear tapered vertical mount attached to the body? There is one bolt that goes through the floor and through the lip of the hat channel, but I think there is also a bolt that goes through the body side. But there is a lip under the body side so the mount will not fit up against it...was there a spacer in there or was the lip cut away?
« Last Edit: June 11, 2014, 08:00:03 PM by 1955CJ-5 »
Re: Original side steps
« Reply #1 on: June 11, 2014, 09:13:29 PM »
If you click on the home page tech tips button, you will eventually find the original step installation instructions..
http://www.cj3apage.com/index/Tech_Tips/Original_side_step_instructions/Origin6.jpg
It mentions a spacer, I didn't see the dimensions listed but I didn't look too hard..
« Reply #2 on: June 11, 2014, 10:01:58 PM »
I looked at that once before, but like you, I didn't look hard enough, and didn't see it mentioned.....but I'll go try it again..
Thanks Bill!
« Reply #3 on: June 11, 2014, 10:06:19 PM »
I looked again. Part of that article shows a converted CJ-5 step, and the one or two pictures of the original steps don't clearly show the rear support...
Maybe someone will have a picture.......but a spacer is probably needed...
« Reply #4 on: June 11, 2014, 10:17:24 PM »
I found this over on the 2a page...there is a link to an updated set of instructions on the 3a page but the link goes nowhere...
My frame holes are already there as this jeep had steps, the remains of one came with the jeep but was pretty rusty....
« Last Edit: June 11, 2014, 10:19:03 PM by 1955CJ-5 »
« Reply #5 on: June 11, 2014, 10:30:15 PM »
The more I look at these and compare them to pictures on the web, the better they look.....
I'll need to clean them up and tack weld a couple of spots, and then some black paint.....
Ready to be ripped off at the first high-center opportunity :D
« Last Edit: June 11, 2014, 10:31:43 PM by 1955CJ-5 »
« Reply #6 on: June 11, 2014, 10:30:18 PM »
We have the how to install steps article, which has the CJ5 step[ mentioned, and there is also a link to the dealer letter and the diagram you posted a bit farther down the tech tips page... Chances are the link it dead as it went to the old website... If you think of it post a link to it so we can update the link back to here....I am not where I can access my parts books, but it is possible the parts listing may say what exactly the spacer is, if you can take a look at one.
Anyone got a CJ3A parts manual handy that can look for us?
« Reply #7 on: June 11, 2014, 10:36:58 PM »
Well Bill, I have one...somehow I never think to look there first...page 102 on the reprint list
But, there is a spacer mentioned but no image in the diagram..
« Last Edit: June 11, 2014, 10:41:35 PM by 1955CJ-5 »
« Reply #8 on: June 11, 2014, 10:38:48 PM »
Here is that link..it doesn't work for me...
http://www.cj3apage.com/Original_side_step_instructions.htm
And here is the link to the 2a thread..
http://www.thecj2apage.com/forums/side-steps_topic27604.html
« Reply #9 on: June 12, 2014, 08:17:01 AM »
We updated the site last year and some path has changed.
You are looking for this one I thnik:
http://www.cj3apage.com/index/Tech_Tips/Original_side_step_instructions.htm
And there is also this one;
http://www.cj3apage.com/index/My_1950/installing_original_steps.htm
« Reply #10 on: June 12, 2014, 11:21:00 AM »
Thanks!
It was that first link that I was looking for..
Edit:  The instructions mention a spacer...I'll just find one that  fits......Thanks again..!
« Last Edit: June 12, 2014, 05:20:11 PM by 1955CJ-5 »
