Author Topic: Generator and starter Paint colors  (Read 3308 times)
Offline James P
« on: May 27, 2014, 07:00:54 PM »
Okay I have done the crazy and completely dissembled the generator and am in the process of rebuilding it and then will be moving on to the starter when I finish. Now I have hit a bit of a snag as I am working on this. What is the original color of the Auto-lite Generators? Also what type of paint do you use that can handle the heat but also will not come off if oil and water get on to the generator ( sorry it is a Jeep it will happen).
Yes pictures will come when I finish it.
« Last Edit: May 27, 2014, 07:01:51 PM by Peckhams52 »
1952 CJ3A
Re: Generator and starter Paint colors
« Reply #1 on: May 27, 2014, 07:20:27 PM »
Here's an original one I took out of the box for the first time last year. Color is black.
Offline James P
« Reply #2 on: May 27, 2014, 08:18:22 PM »
Thanks now just to figure out what type of paint to use. :)
1952 CJ3A
« Reply #3 on: May 27, 2014, 08:39:20 PM »
I'm sure there will be more sophisticated solutions from other members but regular ol'  Rustoleum black has held up pretty well on mine so far.
« Reply #4 on: May 27, 2014, 09:38:27 PM »
I used Duplicolor engine paint.....so far I like it....I used it on the transmission, engine, starter/generator and the oil filter canister....so far so good..it's supposed to withstand 500* which might be a little optimistic...but it has withstood the oil and water spills...
Eastwood sells a two-part epoxy that has a special 2 part aerosol can...expensive though
As always two part auto paint with a hardener would probably be best if you have the equipment......
« Reply #5 on: June 11, 2014, 08:00:42 AM »
I would love to see any pics of the disassembly I am thinking about doing mine. I have a price of $75 each from a local armature shop, not sure of what I would be getting into�
Offline James P
« Reply #6 on: June 11, 2014, 08:01:36 PM »
I have pictures of the disassemble of the starter over on my rebuild page but unfortunately, I failed to take pictures when I did the generator. I ended up using the Dupli-color engine paint in a semi gloss black.
1952 CJ3A
