Author Topic: Carb Issues  (Read 1969 times)
Offline Steve
  • First Project
Carb Issues
« on: April 30, 2014, 01:33:58 AM »
Got the jeep running with rebuilt WO carb. Engine runs beautifully at idle. When I hit the gas pedal the engine chugs and usually stalls. If I run with partial choke 1/4 out engine does much better. Fuel pump is new as are filters. I am stumped about what I should do and check to resolve the problem.� Any thoughts would be appreciated.
I have not messed with the points, could they be causing this sort of issue?
Steve
« Last Edit: April 30, 2014, 01:37:07 AM by marblecreek »
1950 CJ3A Mostly Stock
Re: Carb Issues
« Reply #1 on: April 30, 2014, 05:38:32 AM »
[size=12]Need more info. What is your idle RPM? Does it idle without any choke? What is the condition of your distributor?[/size][/b]
Re: Carb Issues
« Reply #2 on: April 30, 2014, 09:53:59 AM »
You may not have the metering rod set right or the idle to run transfer ports may be clogged.
Offline Steve
  • First Project
Re: Carb Issues
« Reply #3 on: May 01, 2014, 12:14:07 AM »
Thanks guys. I put new points in tonight and things are much better. Also adjusted the carb (still need to mess some more) and things improved still more. I will let you know how it goes when I set the timing and get the carb dialed in.
-Steve
