Author Topic: Key start 3A  (Read 6190 times)
Offline Lee
  • Will-is enthousiast
Key start 3A
« on: December 15, 2013, 12:50:48 PM »
I did a search here first and came up with nothing, so a friend wants to key start his 3A, 1) I can find a supersonic starter.  2) I can modify a 2A starter with the correct tooth drive........So I would rather modify a 2A starter. Question, does anyone have a part number for the correct drive for a 2A starter to fit a 3A ring gear?, If so, I will document the conversion with photo's and post here for others interested in this.
Lee ;)
Re: Key start 3A
« Reply #1 on: December 15, 2013, 04:22:55 PM »
I've never heard of a starter drive that will convert a CJ-2A starter to operate with a 124 tooth ring gear. You could always change the CJ-3A ring gear to 97 teeth, but that's a real project. If you were going to take the time to change the ring gear it may be better to go with the late CJ-3A ring gear with 129 teeth and use the late CJ-3A key start starter. (Edit - forgot, the late starter will also require a different bellhousing too.) A Henry J starter would be the easiest solution but they are difficult to locate. I have seen the stock CJ-3A "kick start" starters modified to key start by adding a universal conversion solenoid that bolts onto the top of the starter. Unfortunately I do not have a source for the conversion solenoids.
« Last Edit: December 16, 2013, 06:29:07 AM by Bob_W »
Offline Lee
Re: Key start 3A
« Reply #2 on: December 15, 2013, 05:43:12 PM »
Bob, thank you for your input, if one were locate a starter drive for a henry J starter, would it not fit a 2A starter, I had a HJ starter and it looked identical to the 2A other than the solenoid....
Lee ;)
Re: Key start 3A
« Reply #3 on: December 15, 2013, 06:10:58 PM »
I've never tried to put a Henry J Bendix on a CJ-2A starter. The CJ-2A Auto-lite starter model MZ-4113 used Armature MZ-2089 with Bendix EBA-46. The Henry J Auto-lite starter model MZ-4163 used Armature MZ-2337 with Bendix EBA-39.
« Last Edit: December 15, 2013, 06:11:34 PM by Bob_W »
Re: Key start 3A
« Reply #4 on: December 15, 2013, 09:46:39 PM »
Offline Lee
Re: Key start 3A
« Reply #5 on: December 15, 2013, 10:51:12 PM »
Thank you Nate, Long time no hear, LOL hope all is well with you. I will do a little digging on this,,,,,,,and thank you Bob for the numbers, a great help.
Lee ;)
Offline Lee
Re: Key start 3A
« Reply #6 on: January 29, 2014, 08:30:34 PM »
Just a little update on this project, I spent some time at a long, used by me starter/alt shop today, I think we have come up with a 9T drive for the 2A starter, should be a bolt on deal, it's ordered!.
Lee ;)
Re: Key start 3A
« Reply #7 on: January 30, 2014, 12:14:29 AM »
Lee,
Please keep up posted on how your new starter idea works out.
Thanks.
Re: Key start 3A
« Reply #8 on: January 30, 2014, 08:25:45 AM »
I've got Henry J starter MZ4163 9-tooth starter if anyone is looking for one.� Needs a new rear and middle bushing.
« Last Edit: January 30, 2014, 08:26:12 AM by bretto »
Mel Mca
  • Guest
Re: Key start 3A
« Reply #9 on: January 19, 2022, 09:47:36 AM »
I've been hounding the web trying to find a replacement MZ 4163 starter. The housing got broke!! If by a slim chance You still have that starter, I WANT IT!!!  :)
