Author Topic: Head bolts or studs?  (Read 3560 times)
Offline Biotex
« on: January 18, 2014, 08:27:36 PM »
I noticed today that my 1950 flat head has bolts holding down the head to the block. My parts engine has studs with nuts.
What does this tell me about the age of either engine? I'm wondering which method is better also?
1950 CJ3A
1990 Comanche
2006 Rubicon
Re: Head bolts or studs?
« Reply #1 on: January 18, 2014, 09:37:57 PM »
I would use head studs. Can you post pictures of the two heads? All mine use studs. I think the bolts came on early non ribbed head engines.
Offline Mike S
  • CJ2A SN CJ2A114542
« Reply #2 on: January 19, 2014, 01:30:45 AM »
AFAIK, all the L134 engines were originally built with studs. Lots of them jet swapped around over the years.
Life is short
Quit your job
Turn off the TV
Go outside and play
Offline Biotex
« Reply #3 on: January 19, 2014, 07:33:26 AM »
1950 CJ3A
1990 Comanche
2006 Rubicon
« Reply #4 on: January 19, 2014, 12:26:03 PM »
Given the choice, I would use studs and nuts.  When removing a stubborn head, a stud give you two points of release.  The nut may come off just fine.  If it is stuck, the stud may come out of the block.
With a bolt, you only have one point of release before it would break.
Offline Lee
  • Will-is enthousiast
« Reply #5 on: January 19, 2014, 11:03:03 PM »
I may be wrong, but was told, industrial engines (welder/generator engines, ect.) had bolts, jeep engines had studs. Industrial engines in most cases were governed and in a generator only ran 1800 rpm, less stress I guess. My 2A had bolts and I replaced them with studs/nuts.
Lee ;)
« Reply #6 on: January 20, 2014, 08:33:51 AM »
The use of proper studs will have the proper thread engagement depth in the block.  Those bolts threads could have a shallow grab.
