Author Topic: CJ5 Clutch In My 3A  (Read 2651 times)
CJ5 Clutch In My 3A
« on: January 08, 2014, 09:18:58 PM »
I was a little surprised to find that I have a CJ5 clutch assembly attached to my L134 -3A engine.� The clutch disc is 9 1/4". The flywheel has a 129 tooth ring gear.� The starter has a 9 tooth Bendix.� �The ring gear, clutch disc and Bendix look near new, and the set up functions fine.
Question...Is there any advantage, or disadvantage to this set up?
Re: CJ5 Clutch In My 3A
« Reply #1 on: January 08, 2014, 09:36:49 PM »
I think the 9 1/4" clutch is the heavy duty disc.....most CJ-5 f-heads used the 8 1/2 disc like the L-heads...
« Last Edit: January 08, 2014, 09:38:19 PM by 1955CJ-5 »
« Reply #2 on: January 08, 2014, 09:43:19 PM »
I've heard the heavy duty clutches can be a bear on the left leg as the pedal pushes a lot harder but I don't know for sure. You plan on doing any heavy duty rock crawling or county fair tractor pulls?
« Last Edit: January 08, 2014, 09:43:38 PM by Ryan_M »
Offline Mike S
  • CJ2A SN CJ2A114542
« Reply #3 on: January 08, 2014, 09:51:24 PM »
The 9.25" HD clutch was an optional upgrade and can be retro-fitted to the standard 134 flywheel. You will have to drill and tap the flywheel, and I would rebalance it. It may require a slightly different clutch shaft. I seriously considered this upgrade for my 2A, but ended up putting a standard clutch in.
The HD clutch will withstand higher torque and wear and tear.
Life is short
Quit your job
Turn off the TV
Go outside and play
Offline ZekeD
« Reply #4 on: January 09, 2014, 11:52:22 PM »
Advantage:  it is there and it works :D
