Author Topic: Dana 18 speedo drive gear removal  (Read 3266 times)
Offline Tucker
« on: November 13, 2013, 10:05:38 PM »
I've torn down my 18 for new bearings and seals, but I cannot get the speedo drive gear off the input shaft.  I was led to believe by my research that it would slide off with just a bit of a bump, but no go.
Any suggestions?  Something I could soak it in?  There's no obvious rust or anything, so I'm somewhat stumped.
Offline SteveW
Re: Dana 18 speedo drive gear removal
« Reply #1 on: November 13, 2013, 10:24:21 PM »
Here is best guide for rebuild
http://www.willystech.com/wt/Model18TCase/Model18TransferCase.html
should just unbolt sleeve and slide off D28 on guide
Can you rock the yoke a bit and see if the gears will unmesh a bit while working drive off?
« Last Edit: November 13, 2013, 10:27:35 PM by Googly_Moogly »
Offline Tucker
« Reply #3 on: November 14, 2013, 11:42:24 AM »
Yeah, I've read through all those threads already.  But each just says slide the speedo drive gear on or off, as if it's supposed to be that easy--which I'm sure it is supposed to be, but it ain't for me.
I was hoping someone else on here had once had a stuck speedo drive gear and discovered some kind of magic potion or juju incantation that helps it slide off.
Offline Tucker
« Reply #4 on: January 02, 2014, 02:05:21 PM »
Quick update in case someone has this same problem in the future: I soaked the entire shaft in CLR for quite a while to dissolve some of the crud that may have built up, and then I used a gear puller to pull on the bearing, which helped slide the speedo gear off.
I've since rebuilt the transfer case, and I installed it a few days ago.  Life is good.
« Reply #5 on: January 02, 2014, 02:17:58 PM »
Was your TC unusually crudded up or rusted inside? I disassembled mine last night and the speedo gear just slid right off like it was supposed to.
Offline Tucker
« Reply #6 on: January 08, 2014, 01:31:54 PM »
No, it was fine.  I think it had just sat for a very long time and the crud had solidified between the gear and the shaft. The oil/water sludge in it, however, looked like, for lack of a better word, brown/yellow/green puke.  Fortunately, because it had a leak, the gears weren't sitting in much of that.
