Author Topic: rear axle at wrong angle  (Read 2087 times)
Offline RussellL
« on: January 04, 2014, 06:03:18 PM »
Hi All,
We have a problem with our jeep.  It is a 56 DJ3A that we converted to a CJ3A when we had to buy a new body a couple of years ago.  It has the L head motor and T90 transmission.  Somewhere along the way it was converted to a 4wd.  I don't know if this was done by changing the frame with all the running gear or just installing a different  trans/transfer and axles.
The problem we are having is that the angle of the drive shaft is severe enough that at full extension of the shocks the u-joints of the drive shaft hit and bind.  We got around that problem by installing angle wedges between the springs and the axles.  Our issue with this is that it really isn't a durable solution.  Recently the axles moved far enough to let the wedges pop out, with all the issues that come from that.   We've bought new wedges but would rather find out why we need them.
When we were doing the restoration and conversion we had to replace quite a few parts, including the rear spline yoke coming out of the transfer case.  The seal ride was chewed up so badly that it would not seal anymore.  We also replaced the rear shocks and the spring bushings, and the rubber transmission mounts on the cross member.   The only parts changed on the drive shaft were the u-joints.  These are the only parts I can think of that might affect the angle of the driveshaft.  Would any of these create an issue that requires a 6 degree wedge to prevent binding?
Any suggestions would be appreciated.
Thanks
Re: rear axle at wrong angle
« Reply #1 on: January 04, 2014, 06:46:01 PM »
While it certainly is not a good thing, I find it is normal for the U-joints to bind slightly when the rear axle is hanging by the suspension.
U-joint angles need to be equal on both ends of a driveshaft, otherwise it will cause a vibration. The normal angle of the powerplant is right about 0 degrees so the rear axle pinion angle should also be 0 degrees.
« Reply #2 on: January 04, 2014, 08:38:19 PM »
Hi Russell,
Post a few photos showing this area on your Willys.  It may help us spot something amiss.
Offline RussellL
« Reply #3 on: January 08, 2014, 01:01:14 AM »
Hey, thanks for the replies.  Unfortunately the jeep is at the ranch a couple of hours away and I won't be able to get any new pictures for a while.  It does seem like the rear axle is not flat when it is sitting on the springs.  The pinion is angled down.
As soon as I can, I'll take some pics.
Russell
