Author Topic: Repair threads on engine studs in block in jeep  (Read 6099 times)
Offline SteveW
« on: November 17, 2013, 05:13:32 PM »
A man named Marty did a guide on the Gee about this but it was cluttered a bit to just link and I didn't do everything he did. I had the block in to have valve guides replaced and hardened seats installed and the repair shop and I agreed to have 2 holes repaired with heli-coils which he did. During assembly by me I had 1 bolt turn a wee bit but I did get it torqued to specs. I had good compression so have left it alone but have decided to make it right and put a copper head gasket on. I ended up with 2 loose head bolts so I bought a Fix A Thred set made by Alcoa ( more on that vs. Helicoil on another topic) It is a pretty easy repair and a couple things to keep in mind.
This is block and I am going to repair the front middle hole and the one by manifold. The front hole goes into the block so no worries about how deep to drill, the other hole is a concern because it has a bottom so depth is something to watch for. Those lines are to lift the head off of block
I didn't show it but you put the head back on the block and use the holes for a guide to drill out block. You need to use a quality bit and a low speed drill that has good control. I used my 18v Cordless Dewalt. The bit needs a good coat of bearing grease to hold the chips and debris, I also put a little inside the hole in block. Works very well
Cleaned bit with brake cleaner between holes and recoated, this was hole with bottom and all that crap came out on the bit
Marty is a mechanic and works on jeep so he used an extension and a sliding breaker bar as a tap handle which I didn't have and could not find. I used a 12pt metric socket 12mm and a 3/8 extension and socket. His theory is you need to have some height to keep the tap straight at the start. I agree and a good coat of grease on the tap also collects chips and lubes the tap. Take your time here
Lot's of crap stuck on the tap, same this as drill, clean and recoat between holes
Very nice clean hole, it is a quality tap
Here is the Fix a Thred insert, a bit of a learning curve over the heli-coil but it is well made
I have no doubt this repair will hold up
My apologies if this is posted else where but I didn't turn up anything on a search
« Last Edit: November 19, 2013, 06:36:49 AM by Googly_Moogly »
Re: Repair threads on engine studs in block in jeep
« Reply #1 on: November 17, 2013, 10:31:50 PM »
Thanks for those pictures and explanation. I know the machinist had to helicoil a couple of the threads in my engine..I think one thermostat housing bolt and a head stud....but I've never done it...
« Reply #2 on: November 18, 2013, 07:55:17 AM »
My 3A block has at least one hole with damaged threads. I was able to get the head stud to grab and hold but I think I'll need to properly repair it if I ever remove and re-install the head.. I have been dreading it. I still am, but this "How-To" makes it seem a little less terrifying and something that I might actually be able to do myself. Thanks for posting.
« Reply #3 on: November 18, 2013, 03:48:03 PM »
Good stuff.  Thanks for posting it. Like everyone, I am hopeful I'll never need your advise. ;)
Offline SteveW
« Reply #4 on: November 18, 2013, 05:40:28 PM »
The using of the head as a guide for drilling out the old hole is what makes this doable. You probably couldn't make a jig that was as accurate. Plus engine stays in the jeep and you can get to 12 of the 15 studs. The bit for the 7/16 insert is 29/64 and that pretty much fills the hole on the head.
« Reply #5 on: November 20, 2013, 11:18:54 AM »
I had to repair two holes in my my block during my rebuild and used Helicoil on both of them.  Like Steve said, the two biggest suggestions are:
1.  Make sure you have a QUALITY drill bit of the CORRECT size.  This is one of those repairs where I felt it was justified to buy a single brand new, high quality cobalt/titanium bit in the correct size.  Many times the heli coil kit comes with a bit.
2.  You have to drill the hole out square.  Use the head or make a fixture either one...just make sure its square.  The other half to this...........make sure you TAP the hole square also.  It won't do much good to drill a square hole it you get the insert crooked.
Just about anyone can do this.  Just take your time, go SLOW and be careful!
« Reply #6 on: November 20, 2013, 08:57:11 PM »
Finally a use for that cracked Supersonic head I bought....But I hope I don't need to use it....
« Reply #7 on: November 27, 2013, 11:11:24 AM »
The only problem with using helicoils to repair head bolts that go into the water jacket is they allow coolant to pass through the threads. It's better to use a solid insert and install it with thread sealer and then thread sealer on the stud.
The copper head gasket will not seal well unless the block surface has been machined and the head surface machined. A fiber head gasket will seal better on old surfaces.
Offline SteveW
« Reply #8 on: November 27, 2013, 01:22:05 PM »
The head was decked and the block was checked and didn't need to be machined. Interesting that machine shop that cleaned and checked my block and the machine shop that did my valve guides and put in hardened seats and the heli coils never mentioned they were not suitable.
« Reply #9 on: November 27, 2013, 11:26:06 PM »
It's not that they are not suitable, they do a good job repairing threads. The only issue is when you use #2 permatex to seal the thread it still will let coolant seep between the insert and the block. It will only seep for a while before it seals it's self.
If the hole is a blind hole it works better. I prefer to use Keenserts for blocks with the bolt holes into the water jacket and use #2 permatex when I put the insert in the block.
