Author Topic: Ride Height  (Read 3694 times)
Ride Height
« on: October 22, 2013, 05:03:59 PM »
I got the body mounted today, and that was a huge leap, but I got to looking at it and it seemed a little high.
I have Bob's book and on the cover the measurement at the rear corner is 19 23/32"
Measuring at the same place the CJ-3a shows 24 3/8" ...seems a little high..
All springs have been replaced with a set from Kaiser Willys
9 leaves in the back, 15" wheels, 700-15 tires.
I jumped up and down on it and it springs right back...
What is your height from the pavement to the bottom of the body, not the cross member, to the ground, at the right rear corner?
Thanks Randy
Re: Ride Height
« Reply #1 on: October 22, 2013, 07:05:20 PM »
Hi Randy,
I did a quick measure.� I also have 15" wheels and 700-15 NDCC tires.�
Measuring from the floor to the curved portion of the rear panel, I get 23" even.� I have the original 9 leafed springs on the rear.� I'm guessing they are a bit tired.
Wheel and tire height...28 3/4" tall.
When measuring from the floor to the underside of the front bumper I get 18 3/8".�
The front has a set of old, but replacement, 10 leafed springs.
I can see how a new set of leaf springs would give you some lift.� At least until they are broken in a bit.
One other thing,� I believe it was Garage Gnome that suggested loosening the spring shackles a little bit to improve the ride.� I don't know if this would drop the height though.
Hope this helps.
Offline SteveW
Re: Ride Height
« Reply #2 on: October 22, 2013, 07:27:25 PM »
My measurement at left rear corner from floor to tub bottom is 23 3/4" I have 16" rims and tires are Dayton Timberline. I took another measurement right at break near driver side in line with front of gas tank and it's 20". Original springs and new Monroe shocks.
Re: Ride Height
« Reply #3 on: October 22, 2013, 07:38:28 PM »
OK Thanks for the measurements....Maybe the 19 23/32" on the cover of Bob's book is based on a full load or something...
My height looks to be more like 1 to 1 1/2" high rather than the� �4+ inches that I initially worked out...
Thanks for the front bumper measurement Tim, mine is 19 3/4" and the tire height is about 28 7/8"....
Lets see what happens when it gets a few miles and a few bumps under it.....
« Last Edit: October 22, 2013, 07:40:48 PM by 1955CJ-5 »
Re: Ride Height
« Reply #4 on: October 22, 2013, 10:11:35 PM »
If you have the shackle nuts/bolts? cranked up, try backing them off a half turn. In the manual, it says something about a clearance between the head and the spring. It is just easier to do a half turn. Your ride will improve greatly as I found out.
Re: Ride Height
« Reply #5 on: October 22, 2013, 10:52:23 PM »
Randy,
You appear to be sitting a consistent 1 3/8" taller than me, front to back.  I can see this as reasonable with you having fresh springs.  I think you're in good shape.
Re: Ride Height
« Reply #6 on: October 22, 2013, 11:08:49 PM »
Yeah I think it's just the newness of the springs....when I looked at it today it seemed a little high, and then I checked the cover of Bob's book which seemed to indicate it was nearly 5 inches high....but the little "condition" note that I found later states that all measurements were made fully loaded...I don't even have the tailgate on yet.
I did back off the shackles as I read that somewhere earlier...probably another post by Garage gnome.....and I think the manual mentions backing them out so they will accept grease..
I think I'm good to go.......
Thanks for all the info....
« Last Edit: October 22, 2013, 11:10:56 PM by 1955CJ-5 »
Re: Ride Height
« Reply #7 on: November 23, 2013, 08:15:02 PM »
For what it's worth the springs have settled a little, after 100 miles or so.
The rear corner is now 23 1/2"...almost an inch lower than it was.
19 1/2" at the fuel tank filler, and 19 3/8" vs 19 3/4" or so from the bottom of the front bumper to the floor....
