Author Topic: Phuel Gauge Phenomenon  (Read 1938 times)
« on: November 23, 2013, 04:50:43 PM »
So, the gauge looks just fine. I turn on the key...nothing. It takes about 4~5 minutes before it registers. It seems accurate enough. Then, after about 15 minutes give or take a few, the lens starts to fog up. It must be moisture as it will disappear after a while...
Do you think it will just eventually go away, or would heating the gauge gently..say 100 degrees or so, dissipate the moisture?
Re: Phuel Gauge Phenomenon
« Reply #1 on: November 23, 2013, 05:03:41 PM »
The lens on mine also fogs up and has since my rebuild. I figured I didn't seal it properly when I removed the bezel and glass to clean it up. I've run it about 3500 miles over the past year and it still does it. I have no idea if it fogged up prior to my rebuild as I really never drove it. Interesting to see another one doing the same thing. I wonder if it's a common problem? Did you take yours apart at any point?
As for accuracy - mine pretty much waves all around any time the jeep is in motion. I roughly determine the mid point of the back-and-forth wiggling to know where my fuel level is. Not sure why yours is delayed. Is the sending unit arm sticking?
« Last Edit: November 23, 2013, 05:06:42 PM by Ryan_M »
Offline SteveW
« Reply #2 on: November 23, 2013, 05:10:42 PM »
I can't answer about the fogging but will try to find an answer about level bouncing around. Larry Long got a Ford part number for the float that eliminates the problem of the cheap plastic floats that let gas inside and ruin the readings of the gauge.
Offline SteveW
« Reply #3 on: November 23, 2013, 05:17:43 PM »
« Reply #4 on: November 23, 2013, 05:46:19 PM »
Mine came with a brass float from Walcks...and it is pretty steady.
That might be the problem...
And it's good to know there is at least one other fuel gauge that fogs up....
Mine has never been apart but based on the condition of the sending unit it hadn't worked in a looooong time...probably just has moisture in it...
Offline stony
« Reply #5 on: November 23, 2013, 06:22:04 PM »
Your problem is that you have moisture in the gauge body.� Not so much that you have fog all the time, but enough so that when the gauge body warms up the humidity in the gauge gets high enough so that it will condense on the coolest part, in this case the glass face.� If you look at the pattern of the fogging it looks like it starts at the hole where the needle comes through.� Just warming it up is not going to do much good, because while the fogging will go away when you heat it, the moisture is still there.� What you need to do is replace the air inside of the gauge with dry air.� Ideally filling the gauge with dry nitrogen and sealing it would be the way to go.� In any case the gauge would need to be sealed well or the nitrogen would gradually be replaced with air and you will have the same problem.  The gauge eventually clears up because it gets warm enough that all of the water stays in the vapor form.
« Last Edit: November 23, 2013, 06:37:01 PM by stonyloam »
Terry
