Author Topic: Oil pan crush washer  (Read 1534 times)
Offline ZekeD
« on: November 20, 2013, 12:13:32 PM »
I have never seen a crush washer that was not solid (copper).  The oil pan washer from Walcks is solid on one side but wraps around a fiber washer with a gap on the other.   Which side goes toward the pan?   Does it matter?
Thanks
Zeke
Re: Oil pan crush washer
« Reply #1 on: November 20, 2013, 05:49:57 PM »
I can't imagine which way it goes....you ordered two, right? ;D
The more I think about it the more it seems that it doesn't matter...
otherwise it would have come with instructions :D
Offline ZekeD
« Reply #2 on: November 20, 2013, 08:18:32 PM »
I could twist it into a M�bius loop and then it would have only one side, and there couldn't be a question.....but I bet it would still leak!  :o
I should have bought two, but then................
« Reply #3 on: November 20, 2013, 08:36:27 PM »
Well, just be sure to thread it through the Worm Hole, then you could be in both dimensions at once..
And what's another little drip, after all?
