Author Topic: Rear seat clip fix  (Read 3680 times)
Offline SteveW
Rear seat clip fix
« on: September 17, 2013, 03:28:52 PM »
Don't have a seat yet but I kept the clips from old tub and decided to see if they could be fixed.
Same problem with flat springs rusty and weak. Body is easy to get apart and clean
coil springs and new dowels
You have to play a bit to get the springs to hold but allow them to spread enough for the seat point to go through opening
I didn't like the bearing of the spring on the rod it kinda moved around a little and rolled for lack of a better term
This solved it by grinding a little flat on the rod so springs sets tight to it and body
Should work fine
Re: Rear seat clip fix
« Reply #1 on: September 17, 2013, 04:17:14 PM »
I've got a rusty set of those...I was wondering if they were repairable..
Thanks!
« Last Edit: September 18, 2013, 10:14:58 AM by 1955CJ-5 »
« Reply #2 on: September 17, 2013, 10:46:19 PM »
Excellent 'How To'.  I have a couple sets that look like scrap metal.  You have given me hope.
Offline Matto
« Reply #3 on: September 18, 2013, 06:10:55 PM »
Nice job! You salvaged original hardware and saved $60 for a repop pair in the process.
« Reply #4 on: November 13, 2013, 05:40:43 PM »
I'm going to give this a try....These things look pretty rough but one step at a time...
SteveW...did you treat them with anything? It looks like you used some Prep and Ready or something...
« Last Edit: November 13, 2013, 05:41:18 PM by 1955CJ-5 »
Offline SteveW
« Reply #5 on: November 13, 2013, 08:11:53 PM »
Just Ospho on the metal. I really like the stuff. I also sandblasted the parts in my cabinet.
« Last Edit: November 13, 2013, 08:13:22 PM by Googly_Moogly »
