Author Topic: Tub Seams  (Read 2672 times)
Offline BMIC
  • Weekend Mechanic
Tub Seams
« on: November 11, 2013, 02:58:42 PM »
I have been cutting and welding in different patches on my tub and for never having used a Mig welder before it is coming along fairly well. Even though the welded patches are strong they will not be water tight. After grinding the welds to a smooth surface what are the options for finishing the tub underside. Bondo? JB Weld? POR 15?
Re: Tub Seams
« Reply #1 on: November 11, 2013, 04:55:45 PM »
It is Maine. TYPAR or a blue tarp cinched tight would be acceptable material� �;D ;D ;D
« Last Edit: November 11, 2013, 04:55:57 PM by Ryan_M »
Offline SteveW
Re: Tub Seams
« Reply #2 on: November 11, 2013, 05:27:12 PM »
There is a product called Lab Metal that has some good features. it is an air dried aluminum patching material that is very strong and if it is scratched it shows a metal rather than bondo. It is fairly pricey and there is a learning curve with it. I used it a lot and depending on how my gumption was that day it went well or drove me nuts. I was disappointed in the caulk they have and really wanted it to seal seams like where the floor and wheel housing were but I couldn't get it to flow. The company that makes it is called Alvin Products. Most Fastenals carry it
http://www.alvinproducts.com/Products/Products.asp?ID=2
Re: Tub Seams
« Reply #3 on: November 11, 2013, 05:41:51 PM »
Use a urethane seam sealer on the backsides of  your patches after priming them with a good epoxy primer or other waterproof primer. Then paint.  Or, prime, paint then seal and repaint.
On the outside if you are going to fill and sand to make things look nice, use a waterproof filler like Tiger hair or kitty hair or other fiberglass based filler for the first coat.
   Then use a lightweight filler like Rage or Evercoat or whatever they sell nowadays. Again, use a waterproof primer....either after your filling or epoxy before your filling. Lots of old school guys say no primer under your filler but.......modern fillers and primers are designed to be used this way.
   That's how I would do it, and some successful pro shops do it. However, in body work there are as many ways to do a job as there are bodymen, and most of the methods work. SO if you hear a differing opinion and the guy can back up his work with a good track record, it is as valid as my opinion.
Offline BMIC
  • Weekend Mechanic
Re: Tub Seams
« Reply #4 on: November 12, 2013, 07:12:59 AM »
t is Maine. TYPAR or a blue tarp cinched tight would be acceptable material� �� �
Ryan your not so far off, I saw a rat rod this summer that had a bikini top made from Typar with a plexiglass sunroof duck taped on the top.
SteveW... I was looking at the Lab Metal product at NAPA the other day but because it is a bit pricey and I am not familiar with it I put it back. It does sound effective.
Bill, Fiberglass reinforced fillers may be the best/easy way to go. Strength, water proof and easy to work with.
Thanks for the info guys ....
Offline BMIC
  • Weekend Mechanic
Re: Tub Seams
« Reply #5 on: November 12, 2013, 01:14:13 PM »
Update.... SteveW I clicked on the web site for "Lab Metal" that you provided and got interested in it. The video on the web site is quite interesting and if it works that well it should be useful to us all. I looked up the local vendor and went over at lunch. Of course they was out of the 12oz size ($19.50) that I wanted to try, according to them it fly's off the shelf. They did have the gallon size at $191.50 (you said pricy) but I can wait until Thursday when they get a new stock.
I'll let everyone know how it works for me..
Thanks Steve for the info, that's why we all log on here everyday...
Offline SteveW
Re: Tub Seams
« Reply #6 on: November 12, 2013, 03:37:05 PM »
A little does go a long way and I did quite a bit with I believe 3 of the small cans. I would not buy a gallon. just like using a mig welder, you think it's pretty good and then you get better at it.
