Author Topic: Battery Hold Down Bracket..  (Read 14932 times)
« on: August 15, 2013, 12:34:39 PM »
I have this funky wire bracket that came with the jeep....it's not an original but probably a period aftermarket...or maybe they still carry them at O'reilly's...
I will be sticking with the 6V system.
I can't seem to find a repro hold-down with the brace that bolts to the fender...nor can I find a picture.
Is the brace not a good idea? Anyone have a picture of an original hold-down?
Re: Battery Hold Down Bracket..
« Reply #1 on: August 15, 2013, 01:46:27 PM »
Hi,
On our website, Jonathan did this:
http://www.cj3apage.com/index/My_1950/installing_an_optima_battery.htm
Mine is a little bit different. I don't know if it's an original or not. I will add picture tomorrow.
Even on the Joe Caprio , the brace from the fender is missing.
http://www.film.queensu.ca/CJ3B/Photos/Siblings/CJ3A/Caprio/Lagler/3AEngineRight.JPG
Offline stony
« Reply #2 on: August 15, 2013, 02:01:39 PM »
Walck's has them.
Terry
« Reply #3 on: August 15, 2013, 02:06:11 PM »
Walcks does'nt also has the brace to the fender.
But it's look good.
http://walcks4wd.com/battery-hold-down-6v-usa-made.html
« Reply #4 on: August 15, 2013, 02:21:52 PM »
Walck's has them, and so does Kaiser-willys, but they don't have the brace like this one..
http://www.ebay.com/itm/190814804253
So now I'm wondering if the brace is not welded on but instead is a separate part...the pictures of the Optima conversion make me think that maybe the brace attaches under the J-bolt wing nut and is not welded to the frame...
Walck's offers the brace as a separate item...Guess I better call....
http://walcks4wd.com/battery-strap-to-fender.html
« Reply #5 on: August 15, 2013, 02:38:37 PM »
I called Walck's....the info that they have shows that the strap was not used after Cj-2a # 215649, even though the stud on the fender is still there on the 3A's....
And, the strap is not welded to the hold-down frame, but it fastens on one end to the fender stud and to the J-bolt on the other....
« Reply #6 on: August 15, 2013, 03:22:54 PM »
Thanks. I'm learning a lot and that' why I love our forum.
« Last Edit: August 15, 2013, 05:30:22 PM by 1955CJ-5 »
« Reply #9 on: August 15, 2013, 07:53:05 PM »
Mine is a '51 and has the brace. I assumed it was original to the Jeep but maybe not?
« Reply #10 on: August 15, 2013, 08:53:06 PM »
I don't know....Maybe BobW will drop in and clear this up....
« Reply #11 on: August 15, 2013, 11:48:50 PM »
Mine is a 49 and looks exactly like Ryan's
« Reply #12 on: August 16, 2013, 08:29:33 AM »
Ok Here is mine and it's a 1950.
It does look different. So you are all getting aftermarket and mine is an original survivor!� ;D :P :P ;D
I found this:
http://www.ebay.com/itm/Jeep-Willys-MB-GPW-Battery-hold-down-frame-original-/271250580079?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f27cb626f&vxp=mtr
Now I should look for the Famous F.
I found this thread interesting and may end out to make a webpage based on it in the tech and tips section.
« Last Edit: August 16, 2013, 10:02:57 AM by QuebecJeep »
« Reply #13 on: August 16, 2013, 10:05:45 AM »
This does not clear up the mystery of the battery bracket but I've seen QTM advertise a few items on ebay as "original" that were not even close. I'm not totally bashing them as I've bought several items and been happy with all of them but I sometimes question the accuracy of the description.
« Reply #14 on: August 16, 2013, 10:09:23 AM »
Wow, $81 and climbing!
Based on what Walck's told me and from what I've seen, the originals did not have the fender strap welded to the hold-down frame. The fender strap fastened to the J-bolt on one end and then of course the fender stud on the other......and that makes sense to me as not all batteries and not all jeeps would have been identical so a little play or adjustment in the strap might have been needed....
But, who really knows? There could easily have been more than one type hold-down that Willys used over the years....
