Author Topic: Carb. V gasket is it needed?  (Read 1482 times)
Offline Shalka04
« on: November 03, 2013, 12:56:56 AM »
So i'm going to swap out my Solex piece of crap tomorrow for my recently returned & Rebuilt Carter.  :-)  Life will be good again.
Here's the issue / problem.  The Carter is slightly taller then the Solaex, and as a result my airhorn tends to rub on the underside of the hood, when the carter is installed.
If I go with a regular gasket instead of the special V shaped one to go between the carb and the manifold I will avoid further rubbing.
How critical is that special  gasket with the V built into it?
Thanks for your thoughts,
-John
Re: Carb. V gasket is it needed?
« Reply #1 on: November 03, 2013, 04:52:57 PM »
If you have an L134 flat head engine with original manifolds and air cleaner crossover pipe you should have about a half an inch between the hood and the crossover pipe. Mine does and I am using the thick original gasket with my carb.
