Author Topic: Dimmer switch....  (Read 4745 times)
Dimmer switch....
« on: September 03, 2013, 09:24:03 PM »
My dimmer switch doesn't seem to work..no continuity between any of the poles, in either switch position...so I'm looking but can't find one that looks like this one....most have the one-piece cast housing...
What does the original look like??
Re: Dimmer switch....
« Reply #1 on: September 03, 2013, 09:33:10 PM »
Mine was dead too. I'd like to think it was original but I have no way to know for sure. Looks pretty much the same as yours. I bought a new one from Walcks. Here's the old one:
« Reply #2 on: September 03, 2013, 09:58:35 PM »
Yes, I'd say they are identical....but mine's a little rustier!
Thanks for the picture..!
I'm going to see if I can get mine apart without breaking it....nothing to loose....
« Reply #3 on: September 03, 2013, 10:03:54 PM »
Let me know if you are able to repair yours. I guess that's why I've kept mine around. Might be another one of those rainy day projects....
« Last Edit: September 03, 2013, 10:04:10 PM by Ryan_M »
« Reply #4 on: September 03, 2013, 10:54:36 PM »
Don't save it for a whole day....an hour maybe..
I carefully straightened the tabs holding the back on..
I cleaned all the contacts, and lubed the mechanism with some light grease
assembled it, and it works!
« Last Edit: September 03, 2013, 11:08:28 PM by 1955CJ-5 »
« Reply #5 on: September 03, 2013, 10:59:41 PM »
Well, I was so pleased with the dimmer, I tackled the headlight switch..
The tabs are smaller so a very small standard screwdriver did the initial bends..
Parts are more or less in order here and oriented correctly
You can see the corroded terminals
cleaned...
Lubed and re-assembled...It's smooth and it works!
Offline stony
« Reply #6 on: September 04, 2013, 01:53:11 AM »
It is so great to see someone fix their old stuff!!!! ;)
Terry
« Reply #7 on: September 04, 2013, 07:55:02 AM »
Thanks for posting these repairs. Generally a repaired original part is superior to a brand new reproduction component.
« Reply #8 on: September 04, 2013, 02:56:21 PM »
I don't think there is anything more satisfying than preserving the original equipment, in this case the switches, and re-installing for another 60+ years of service.
« Last Edit: September 05, 2013, 10:13:45 AM by 1955CJ-5 »
