Author Topic: Frame refurbishment  (Read 2397 times)
Offline CJPilot
  • Shade Tree Mechanic
Frame refurbishment
« on: September 01, 2013, 09:18:10 AM »
The frame that came with my CJ3A was usable but had the typical Northeast pitting.� I happened to run across a pretty decent one.� The pitting is not as bad and it some how it followed me home.� Now I want to fix it up proper.
 I was planning on replacing the front and rear cross members on my original frame so I have them.� I have a good battery holder I�m also going to use.� My question is what should I do to the new frame before I have it sandblasted and painted? Should I do anything with the clutch pedal mount, the bell crank area?
Steve
Re: Frame refurbishment
« Reply #1 on: September 01, 2013, 12:05:28 PM »
You might find a couple of wooden dowels that fit the clutch tube and steering bellcrank mount...or, since it's likely you will replace the old bellcrank pin and clutch/brake tube, you could just leave them in, if protecting the interior of the tubes is your goal...
Nice looking frame.....!
Offline CJPilot
« Reply #2 on: September 01, 2013, 12:37:32 PM »
That�s what I need to figure out.� I see Walcks has the clutch/brake tube welded in the bracket. Not to sure about the quality. Does anybody have just the tube so I don�t have to mess with the rivets and how about a grease-able version.� Is there a repair for the bellcrank pivot? Trying to get all this a done before the sandblasting so I can paint it before the frame starts to flash rust.
Steve
« Reply #3 on: September 01, 2013, 02:46:21 PM »
There is a repair kit for the steering pin, includes the bearings, seals, shaft and spacer and I can't remember what else...
http://walcks4wd.com/bell-crank-kit-78-2a-3a-3b-cj5.html
And you can buy just the inner crossover clutch/brake tube. It is the one that slides into the riveted frame bracket...i bought one and it was excellent quality and a good fit...
http://walcks4wd.com/cross-tube-brake-pedal.html
Walcks is having a 10% off sale this weekend!!
