Author Topic: Tapping a thread for temp gauge  (Read 1064 times)
Offline 3aJeeper
  • Luvs me a flatfender Jeep!
« on: August 30, 2013, 09:50:22 AM »
Finally getting a chance to get back and do a little work on the jeep.
I am replacing the temp gauge with mechanical one. I had to drill out a brass fitting so I can make the mechanical gauge fit. I didn't completely drill it out so as not to destroy the threads in the block.
I need to chase the threads to clean out the last little bit of brass, but I don't know what tap I should use. How do I go about figuring that out? I've not done this before so I really don't want to monkey-up the block.
Here's a pic from an earlier thread pointing out the brass fitting I drilled out.
1951 CJ3a
F-134 Hurricane engine
Re: Tapping a thread for temp gauge
« Reply #1 on: August 30, 2013, 10:16:16 AM »
I think that is a 1/2" tapered pipe thread.
