Author Topic: Knuckle Weld  (Read 1120 times)
Offline PaulS
Knuckle Weld
« on: August 14, 2013, 11:57:35 AM »
Here's a picture of the weld on the knuckle of my Dana 25 axle, which (AFAIK) dates from c1949.� I had sandblasted the axle housing, but the morning dew got to it leaving the rust pattern you see (which was easily cleaned off).�
It's the circumferential weld that really intrigues me.� The other welds (the one holding the brake hose holder in the picture, and the ones on the spring mounts, not in the picture) are clearly done by hand.� But this one weld is not--it's a much higher quality.� Since they didn't have robotic welders in 1949, how did they do this?
This is just curiosity--I have no inclination to try to do anything like this myself!
-Paul
Offline AZJeepNut
Re: Knuckle Weld
« Reply #1 on: August 14, 2013, 05:55:49 PM »
Google search found this on http://www.weldinghistory.org/whfolder/folder/wh1900.html
In the 1920s . . .
"The automotive industry began using Automatic Welding with a bare wire fed to the workpiece to the production of differential housings."
Not exactly robotic but an automatic wire feed to an electric weld head held in position over a rotating workpiece would be just as good.
« Last Edit: August 14, 2013, 05:56:31 PM by AZJeepNut »
1950 CJ-3A
