Hi, I ordered a drag link repair kit. I did try to installed it without success.
I had two problems.
First one is the screw are not the same.
The lenght of the thread is longer on the new one and the depth of the slot for the cutter pin are shorter.
I was not able to screw them enough to get the cutter pin goes through.
Here is pictures of the repro versus the original side by side.
I end up the put back the original.
Also, the plate that keep the rubber seal in place is a very thin metal plate. I kept my old one since it was harder and had some spring in it. Also, I think they are made in stainless.
Does anyone has some feedbacks?
