Author Topic: Body compatibility: 3A vs 2A vs M38  (Read 1938 times)
Offline PaulS
« on: July 03, 2013, 04:14:52 PM »
How similar are the bodies on the 3A, 2A, and M38?  To what extent can one be swapped out for another?
I presume that most or all of the other parts can be easily swapped.  Correct?
-Paul
Re: Body compatibility: 3A vs 2A vs M38
« Reply #1 on: July 03, 2013, 04:57:25 PM »
I'll tell you what I know...
The wheel house tops are 2" longer on a 2a, that translates into less leg room.
The 3a windshield frame is taller than the 2a, but I don't know by how much.
The M-38 has a larger opening for the fuel filler neck, and the floor pan over the transmission is removable on an M-38, much like the early CJ-5. Some M-38's have a larger/deeper fuel tank..
M-38 dash is very different-gauge location, switches and it has a glove box....2a and 3a are very similar..
I'm sure there are a multitude of other M-38 vs 3a differences..top bow fastening, grab handles, hinged grill, brush guards on the headlights etc
I don't know about frame mounts....
« Last Edit: July 03, 2013, 04:58:45 PM by 1955CJ-5 »
« Reply #2 on: July 03, 2013, 08:47:21 PM »
All the 2A, 3A and M38 body parts will bolt together on any one of those chassis. Randy cover the major differences though.
