Author Topic: windshield doesn�t rest  (Read 10032 times)
Offline Carlos
  • Willys for ever.
« on: June 13, 2013, 09:06:55 PM »
 I have a consultation, is the case that my CJ3A of 1950 when bending the windshield doesn't rest� over the wooden supports that are in the hood and don't I understand why, somebody would can to give me some idea?
Edit by Admin
I've re-sized all the pics in this thread to 800 wide so they can be seen by everybody. Also made the file size much smaller for those on dial-up. Hope this helps.
« Last Edit: June 19, 2013, 09:03:27 AM by johnrb3b »
Re: windshield doesn�t rest
« Reply #1 on: June 13, 2013, 09:27:11 PM »
Somebody could have put the wooden supports in the wrong spot. How far from the end of the hood are they? Can you post a picture?
« Reply #2 on: June 13, 2013, 09:35:58 PM »
This is how mine looked...how is yours different?
(wow that's a big picture!)
« Last Edit: June 19, 2013, 08:55:58 AM by johnrb3b »
« Reply #3 on: June 14, 2013, 08:32:14 PM »
Where does it rest?   A little more info would help.
Offline Carlos
  • Willys for ever.
« Reply #4 on: June 15, 2013, 08:49:52 PM »
This are some pictures of my Willys
« Last Edit: June 19, 2013, 08:57:06 AM by johnrb3b »
« Reply #5 on: June 15, 2013, 11:15:37 PM »
Nice jeep!
Could it be that the windshield is bent or raked back too much?
When you lay it down does the part near the hinge hit first before the top f the windshield touches the blocks?
Offline Carlos
  • Willys for ever.
« Reply #6 on: June 16, 2013, 12:52:03 AM »
It doesn't seem to be bent and when I bend it the first part that it rest over the hood it is the part of the ventilation window, then it cannot bend more, not yet I have a picture that shows it, but I have found this in the forum where it show a willys to which doesn't rest the windshield the same as to mine.
Offline Carlos
  • Willys for ever.
« Reply #7 on: June 16, 2013, 09:04:03 PM »
Hello, again bothering, this day I takes him some pictures to my CJ3A and I could check measures of the wooden blocks and their location, I go up the pictures so that you can appreciate it, the dimensions of the blocks that I have are 11.2x3.8x4 centimeters of high, both are located at the same distance of the hood center (33 cm) and to 3.5 centimeters of the hood edge, I understand that starting from the CJ3A this is therefore the wipers they already go located in the low part from the windshield contrary to the previous models where were up and for that reason it was necessary to put the blocks at different distances, I also find that the blocks of the CJ3A are more high that those of the other ones, I will thank a lot if somebody can give me a small drawing with the correct dimensions for the CJ3A, it could send this way them to make since I know a good carpenter, I wait their comments, greetings.
Offline Carlos
  • Willys for ever.
« Reply #8 on: June 16, 2013, 09:12:49 PM »
Here is the pictures:
« Last Edit: June 19, 2013, 08:58:55 AM by johnrb3b »
« Reply #9 on: June 16, 2013, 09:28:48 PM »
The blocks I have are reproductions, they are:
11.8 cm long
5.5 cm high
2.6 cm thick
Does that help?
Can you adjust your hinge points so the windshield lays flat in relation to the hood?
Also, can you make your pictures smaller? They are huge on my screen and hard to view..
Good luck!
Offline Carlos
  • Willys for ever.
« Reply #10 on: June 16, 2013, 09:33:06 PM »
Thanks, for the datail, and sorry for the pictures sizes, I am not sure how can do.
« Reply #11 on: June 16, 2013, 09:37:29 PM »
I'm not sure about the pictures either.....it might be a camera setting....
Offline Carlos
  • Willys for ever.
« Reply #12 on: June 16, 2013, 09:40:46 PM »
Ok, maybe, I try to take a new pictures whit low resolution, I hope is better, bue thanks again and excuse me for that.
« Reply #13 on: June 16, 2013, 09:49:03 PM »
Just a suggestion.....
The big pictures sure show every detail!
« Reply #14 on: June 16, 2013, 09:52:06 PM »
Here are some pics of mine.
