Author Topic: L-134 engine rear main seal...??  (Read 8246 times)
« on: June 05, 2013, 01:41:18 PM »
My engine is at the machine shop and he was going to start assembling this week...but...
The Felpro seal that came with the gasket kit is a rope seal..
He ordered a Victor JV-687 rubber seal but in the box was another rope seal!!
So I'm looking for a rubber rear main seal for the L-134....
Any ideas?
« Last Edit: June 05, 2013, 01:41:47 PM by 1955CJ-5 »
Re: L-134 engine rear main seal...??
« Reply #1 on: June 05, 2013, 02:03:19 PM »
There has been a whole lot of serious problems with the rubber type of seals. A rope seal, properly installed, is the way to go with these motors.
Do a few searches over on the www.g503.com discussion boards for rear main seal failures, you'll see just how bad they were.. Engine lockups and rear main bearing failures were common.
« Reply #2 on: June 05, 2013, 02:10:19 PM »
http://g503.com/forums/viewtopic.php?f=4&t=161301
Check out this thread in particular...800093 Victor is not to be trusted.
« Reply #3 on: June 05, 2013, 02:11:12 PM »
Thanks Bill...
That does not sound good....of course I just found the new and improved neoprene seal at Kaiser-willys and I ordered it...
Whether or not we use it is another matter....
You know I checked g503 for a rubber seal and they only list the rope seal...for good reason maybe....
« Reply #4 on: June 05, 2013, 02:36:05 PM »
OK Bill,
I talked with a fellow at Ron Fitzpatrick/G503 and they do not sell the rubber seals for that very reason...serious problems from the seals and that is why FelPro or Victor  no longer sell the rubber seals.
K-W was nice enough to cancel my order...
We will use the Felpro rope seal..
Thanks Bill...you probably just saved my newly rebuilt engine!!
« Reply #5 on: June 05, 2013, 02:46:46 PM »
So Bill, I think you should get a free ride in this future new rebuilt jeep! It worth it!
« Reply #6 on: June 05, 2013, 04:16:26 PM »
OK Bill,
I talked with a fellow at Ron Fitzpatrick/G503 and they do not sell the rubber seals for that very reason...serious problems from the seals and that is why FelPro or Victor� no longer sell the rubber seals.�
I do not know anything about the seals that KW sells...they may be fine for all I know. Supposedly the older Victor seals were fine, but they are no longer any good.
Read up on how to install the rope seals.. They take a little work to install correctly.
« Reply #7 on: June 05, 2013, 07:13:43 PM »
I will go to the local MVPA show tomorrow and ask around about the seals....
The machinist thinks it will be fine as all the surfaces are machined and clean so it should be a good installation.
I see the shop manual mentions a "lip" seal that was used in later production l-heads..The machinist thinks that the lip seal may have had something to do with the fording/waterproofing.
I will continue to research this...but I'd rather have a few drips on the floor than a seized or damaged engine...can you imagine thinking every time you start it whether or not this will be the day that it blows?
« Reply #8 on: June 05, 2013, 09:14:50 PM »
Randy,� I'm with Bill on this.� I used the modern style seal thinking it would be an improvement over the rope seal.� It leaked almost immediately.� After the first driving season was over, I replaced it with the Felpro rope seal.� No leaks.
Well, let me qualify this...no leaks from the rear main. ;D
« Reply #9 on: June 05, 2013, 09:18:52 PM »
The rubber "lip" seal was first introduced on the military waterproof vehicles and was later factory installed on all the 4 cylinder engines. After reading all the stories and problems I'd say the safe bet is a rope seal. The tolerances of early components (pre rubber seal) may not be up to the requirements for a rubber seal, but the rope will just fit in any size space. If you check the turning torque of the crankshaft with a rubber seal installed you will be fine. Too much torque = friction = heat and problems.
« Reply #10 on: June 05, 2013, 10:03:02 PM »
Thanks Bob and Tim..
Rope sounds good to me...
