Author Topic: Full front floor with Trans hump  (Read 3327 times)
Offline Buildinghippy
  • Plays With Jeeps
« on: May 04, 2013, 09:43:58 PM »
Have anyone here seen this or have used it? I'm guessing MDJuan maks it. I have seen it for sale on a few sites. Thinking of using it as my floor is about 60% gone and my hump has been hacked up bad
1950 CJ3A, cj2a windshild, ford 289
Re: Full front floor with Trans hump
« Reply #1 on: May 05, 2013, 08:58:07 AM »
Hipp,
I have one sitting here.  I haven't used it in a Willys yet.  If your question is about fit, I can't help.   If it's about value and quality, I can give you an assessment.
It comes with the floor support hat channels and triangular support gussets, though they seem to be a bet 'under gauged' to me.
Offline CJPilot
  • Shade Tree Mechanic
« Reply #2 on: May 05, 2013, 10:18:10 AM »
[size=12]I would not go that route.� I�d look into separate pieces that you can� fit into place and weld.�
If it�s any thing like the repo tub it will be a lot easer to do it that way. You won�t have to cut it apart first to make it fit.
Another point, try and save your original sheet metal that has the pedal holes, accelerator linkage hole , etc
Best of luck
Steve
[/size]
  • Plays With Jeeps
« Reply #3 on: May 05, 2013, 05:45:27 PM »
I'm really looking in to it for the Trans hump, I have not seen just it for sale. Most of the front half has been replaced and cut up badly.
This is what I'm working with
Offline 3aJeeper
  • Luvs me a flatfender Jeep!
« Reply #4 on: May 05, 2013, 06:48:51 PM »
I've been thinking about using the replacement floor too. I assume that there will be some modification as well. The transmission hump on mine has also been hacked and welded. If it was solid I'd leave it in place as others suggest and build out from there. But this is not the case.
1951 CJ3a
F-134 Hurricane engine
  • Plays With Jeeps
« Reply #5 on: May 05, 2013, 07:31:44 PM »
Went out and cut out what the PO used as a cover.
This is what is left
This is what I pulled out, look to be a premade piece.
« Reply #6 on: May 05, 2013, 09:14:03 PM »
Hippy,
I often refer to the transmission hump as the 'Spine' of the Willys tub.� With a good one, you can do what CJPilot suggests.� Without a good hump to start from...you've got trouble.
I haven't seen just the hump for sale.� I had to track down a donor tub with a good hump so I can avoid the repro floor.� The whole tub cost me $200.00� Far less than the repro-floor will cost.� ( I haven't bought it from the guy yet.� We have been negotiating.)�
