Author Topic: How heavy is a tub????  (Read 6724 times)
Offline ZekeD
« on: March 20, 2013, 10:34:34 PM »
I have reached a fatefull (sic) decision.    I am going to remove the tub!
How heavy is it?   Is it a b$&@$)? To do?   What do I watch out for?
TIA
Z.
Re: How heavy is a tub????
« Reply #1 on: March 20, 2013, 10:49:03 PM »
I'm going to try the same thing soon. I've been told that a bare tub weighs in the neighborhood of 210lbs.
I've been thinking of fastening some 2x4's together, and putting one set under the front frame mounts and the other under the rear/bed frame mounts, and lifting either with an engine hoist or just a little at a time by hand, resting the 2x4's on saw horses or something until the frame can be rolled out.............
Can't wait to see what others have done!
Offline Pats4WD
« Reply #2 on: March 20, 2013, 10:55:22 PM »
My experience was kind of scary.  It invloved a couple of planks in the rafters of the shop, a come-along and two ratchet straps.  Keep in mind that the tub has to move back or the frame move foreward as you lift in order to clear steering column.
Proud owner of Grandads 51 CJ3A
Offline ZekeD
« Reply #3 on: March 20, 2013, 11:11:11 PM »
What aboutthe steering column????   Does it have to come out?   What do you have to remember to put it back in?
« Reply #4 on: March 20, 2013, 11:13:09 PM »
It all depends on how much you leave attached to it. I remember reading somewhere recently a figure of 275 lbs. but I don't know if that included any other goodies. Heavy layers of paint, undercoating, 1/4 inch plate steel patches, layers of mulch and leaves, road tar in the wheelwells, and stray cats and dogs all add to the weight. If your floor is a flintstone special it might be a little lighter. I had a jeep where the whole rear floor and wheelwells were made of scrap plate steel, I dismantled that one inplace as it was too heavy to pull. I have a tub by my shop now, I can move it around by myself by walking it back and forth, with two people it is easier, three is just right. It has been rhinolined and that is heavy stuff.
So far as tricks.....get your steering wheel and column out of the way, you can take the steering column out once the wheel is off as long as you have the fender off anyway...Take the top off the tranny with the shifter cane, and stuff it full of rags. Your 4WD shifters probably won't come off easily but if you can get that pivot bolt out it will make life easier, otherwise it will be your only obstacle left... Pedals, gas tank, wiring, fuel line and exhaust connectors and hangers if attached all add to the fun. Soak all your fasteners with Kroil or PB Blaster or whatever juice you use a day or two ahead...
You asked about the column, while I was typing.. You do NOT have to remove it but......it is a lot easier to do it that way. If you have a well trained crew and not a bunch of slambang happy crazies, they can carefully thread teh column out thru the tub hole as you lift it up..You will have to have the steering wheel and any turn signal stuff off..
Are you pulling it to repair or replace with new or ?? IF to repair it may be worth putting some temporary bracing in it.
« Last Edit: March 20, 2013, 11:16:24 PM by F_Bill »
Offline ZekeD
« Reply #5 on: March 20, 2013, 11:14:14 PM »
I have a 2 ton travel lift in my shop but I have no idea where to fasten the chains to the tub, if and when I can get it loose from the frame.    Gonna be fun.
Z.
Offline ZekeD
« Reply #6 on: March 20, 2013, 11:17:04 PM »
Damn, Bill wouldnt it be easier to cut all of it off with a torch and re-weld it laterr?
Z.
Offline ZekeD
« Reply #7 on: March 20, 2013, 11:19:16 PM »
F Bill,   I plan to repair and use as a farm jeep.  No trailer Queen, just fun for an old man.
« Reply #8 on: March 20, 2013, 11:26:03 PM »
Z.
Sometimes fast and easy now makes it hard work �and expensive later.....Other times you just need to know what to cut and what to save. �Speaking of which don't toss anything until you finish the job... SOme of the ugliest looking stuff might turn out to be really important...
If you have a functional original temperature gage, you will have to remove it from the head before pulling the tub.. Lots of PB, lots of care....really easy to snap it off. If you do, there was a recent post about repairing the gages....Speedo cable as well has to be pulled, oil pressure line has a connection.
Junkyard removal of parts and pieces, cutting wires, torching bolts, etc..has its place. If you do no harm to things you want to save. Be really careful with a cutting torch, as it is pretty easy to torch the good metal too. Not that I have ever done such a thing, at least today... �:-[
And I forgot, if you have a PTO pull off the linkage before pulling the tub.
« Last Edit: March 20, 2013, 11:28:36 PM by F_Bill »
« Reply #9 on: March 20, 2013, 11:38:06 PM »
This is how I did it. �I didn't remove the steering column, but it is easier if you do. �I threaded the needle in reverse. �Up a little...back a little...and so on. �
After removing the tub, I used rope and rafters in my garage to manipulate, turn, flip the tub as needed.
If you have a couple friends, some beer and pizza handy, you will easily have the tub off in moments.
Offline ZekeD
« Reply #10 on: March 20, 2013, 11:47:07 PM »
OK! but your helper is a lot prettier than any of mine!
Thanks for the help. It is reassuring that it CAN be done by mere mortals..
Except for F Bill..... we all know that he is a C3 God
Offline ZekeD
« Reply #11 on: March 20, 2013, 11:48:39 PM »
F Bill:  Yes I have a front PTO with winch.     Should that be first on the relief list?
« Reply #12 on: March 21, 2013, 02:28:42 AM »
Here's how I pulled the tub, with the steering column still in place.  I took the picture while 5 friends didn't work very hard.
« Reply #13 on: March 21, 2013, 05:49:36 AM »
My dad and I were able to set the new unpainted tub on my frame just by picking it up and setting it down. We used other means to yank the old one off and put the painted one on. My old tub was heavily bubbafied, so it probably weighed more than my new painted one.
Old tub off.
New tub on.
« Last Edit: March 21, 2013, 05:52:06 AM by garage_gnome »
« Reply #14 on: March 21, 2013, 05:50:55 AM »
Here's how mine came off. No special equipment needed. I enlisted only the help of my wife (who barely rings up triple digits on a scale) for some added muscle. I left the steering column and shift levers in place but removed everything else. We slid the tub off backwards, stood it on end, and then rolled the chassis out of the way. Re-install was pretty much the same process but with the help of the aforementioned wife plus two other people. Still not bad, but if Athawk lived closer I would have commandeered his Kubota instead.
