Author Topic: Oil Pressure Part  (Read 1221 times)
Offline BMIC
  • Weekend Mechanic
Oil Pressure Part
« on: March 01, 2013, 11:51:08 AM »
Little help please.... Does anyone know the size of the brass elbow fitting that attaches the oil pressure line to the block? Napa part #?
Thanks
Re: Oil Pressure Part
« Reply #1 on: March 01, 2013, 12:18:22 PM »
BMIC,
I believe the Napa # is 402X4. �If it's not that one, it's probably # 402X3
Grab one of their 1/4" brake lines and bring it to the counter with you. �If the brake line fits in the compression side of the elbow, this will be the right part to fit in the block.
Edit...And I believe either will work.  Just the wrench size on the elbow might be different.
« Last Edit: March 01, 2013, 12:26:16 PM by athawk11 »
Offline BMIC
  • Weekend Mechanic
« Reply #2 on: March 01, 2013, 01:58:54 PM »
Thanks Tim, HUGE help.... there is always one small piece you forget to order that holds up a smooth weekend.
« Reply #3 on: March 01, 2013, 02:36:24 PM »
Should be 1/8" NPT to 1/4" tubing.
