Author Topic: Hood  (Read 8539 times)
Re: Hood
« Reply #15 on: February 10, 2013, 09:20:26 PM »
Hi I'm Rommel Juan from MDJuan.
Here is an MDJuan repro hood installed on an original CJ2a tub.
 i can give you more info if you like. Just let me know what you need :)
Cheers
Rommel
Rommel it might be good to show how th eoriginal hood fits, too.
Re: Hood
« Reply #16 on: February 11, 2013, 12:10:09 AM »
Cheers
Rommel
Hello Rommel,
  My post on this thread above states that when I took a straight edge and put it along the upper part of the radius above the embossed WILLYS there was a indentation beginning at the radius and going towards the center of the hood exactly the same on both sides(as though someone had sat on it).  It started at zero at the front to 1/4 inch indentation in the middle and ending up at zero at the back.  So, I had to fill the entire area, several inches long and about 4 inches wide with it being 1/4 inch deep in the middle.  I didn't see it until I sprayed primer before painting.  While the primer was wet, still glossy, it was very evident.
Even in the picture you have supplied here of the new hood on the 2A, it looks to me that if the paint were glossy there would be a visible indentation.  It's hard to tell in the photo.  Would you please place a straight edge on that hood in this photo and take a few more pics from different angles so I can see that there really is no indentation?
I wish I had pics of the filling process.  But that was a part of my Jeep restoration I was not proud of sod I took no pics.
Thanks for coming on the CJ-3A page and addressing our concerns.
Offline duffer
  • Just old
Re: Hood
« Reply #17 on: February 12, 2013, 12:26:49 PM »
The cowl radius fit was exactly the same problem I had with a 3B repo hood which I believe was MD Juan. �It is still sitting in the shed, in its shipping box, almost 40 years later. �That was the first and last reproduction steel Willys body parts I have bought. �I ended up just building my own hood from aluminum-something you can sit on without bending it.
John, Bozeman, MT
Offline Jesse
Re: Hood
« Reply #18 on: February 12, 2013, 05:18:52 PM »
I think the classic enterprises stuff is pretty dang good myself, but why not just buy an original?
http://cj3apage.com/forum-yabb/YaBB.pl?num=1358400095
Re: Hood
« Reply #19 on: February 12, 2013, 08:29:59 PM »
Jesse,
You may be in an area where original Willys hoods are found on every corner. ;)  In Colorado, good original Willys sheet metal is like the elusive hens tooth.  Very rare.  And if in great condition, very very expensive.
Offline Rommel_Juan
Re: Hood
« Reply #20 on: February 13, 2013, 03:16:24 AM »
Hello Rommel,
 ï¿½My post on this thread above states that when I took a straight edge and put it along the upper part of the radius above the embossed WILLYS there was a indentation beginning at the radius and going towards the center of the hood exactly the same on both sides(as though someone had sat on it). �It started at zero at the front to 1/4 inch indentation in the middle and ending up at zero at the back. �So, I had to fill the entire area, several inches long and about 4 inches wide with it being 1/4 inch deep in the middle. �I didn't see it until I sprayed primer before painting. �While the primer was wet, still glossy, it was very evident.
Even in the picture you have supplied here of the new hood on the 2A, it looks to me that if the paint were glossy there would be a visible indentation. �It's hard to tell in the photo. �Would you please place a straight edge on that hood in this photo and take a few more pics from different angles so I can see that there really is no indentation? �
I wish I had pics of the filling process. �But that was a part of my Jeep restoration I was not proud of sod I took no pics.
here is a picture of our hood. We have solved that problem by fixing our bending die in 2008.
there are no more indents.
rommel
Offline Rommel_Juan
Re: Hood
« Reply #21 on: February 13, 2013, 09:17:54 AM »
Cheers
Rommel
here you go:
Offline Jesse
Re: Hood
« Reply #22 on: February 13, 2013, 09:56:19 AM »
Just a joke, I'm the one selling an original. (And MN jeeps are always wasted so it is a good find)
-Jesse
Re: Hood
« Reply #23 on: February 13, 2013, 06:39:44 PM »
Cheers
Rommel
here you go:
Rommell,
  Thanks for the response with pics that show that indents are gone.  I purchased my tub, fenders, and hood in 2007.  I should have waited a bit.  Thanks for your ongoing efforts to make a better reproduction part.  Again, thanks for joining our Willys Jeep forums.
« Last Edit: February 13, 2013, 06:40:26 PM by calvinhunt »
