Author Topic: Shackle U-bolt source  (Read 1589 times)
« on: February 04, 2013, 06:23:32 PM »
I bought a set of 4 "U" shackles  for my CJ-5 last summer and they seem to work OK. There were two problems with the install. On the hex head a 7/8" end wrench would fit across maybe two opposing flats but not the others. So I got the file out and took just a little off each flat until the wrench would fit. ....I'm using Craftsman and Mac tools...so with four shackles and 6 flats per that was 24 filing operations....Next issue was when I went to grease the shackles they would not take any grease...unless you backed them out a bit and then all was good.
Do all U-shackles come out of the same factory? Can I get a better quality version, other than NOS?
Thanks...
Re: Shackle U-bolt source
« Reply #1 on: February 04, 2013, 07:07:00 PM »
The bolts should be backed out a little as per the spec in the manual. I did half a turn on mine. I think it is like 3/32". I just use an adjustable wrench on mine.  ;D No, mine fit a regular wrench perfectly. They were Omix-Ada brand.
« Reply #2 on: February 04, 2013, 07:13:33 PM »
Maybe I just got lucky and and got the last set before they re-tooled!   I'll check Walck's and where they get them...
So it seems the backing out is normal. One of these days I'll learn to check the book even for the "obvious" things!!
