Author Topic: Brake Question  (Read 1203 times)
Offline BMIC
  • Weekend Mechanic
Brake Question
« on: January 22, 2013, 12:28:07 PM »
I am finishing up my front axle brake lines and need some help. Does the front axle brake line tee bolt directly to the axle or mount on a bracket? As if 9" brakes are not enough of a challange, mine came with no front brakes. I've looked through many posts and pictures (thank you Bretto, your pictures are a great reference) and can not find a clear view of the front brake line configuration.
Thanks
Bruce
Re: Brake Question
« Reply #1 on: January 23, 2013, 01:49:30 AM »
Bruce,
 ï¿½Here's a couple of pics from my restoration. �Maybe this is what you're looking for. This first pic shows the "T" Fitting. �It bolts to a standoff bracket that is welded to the front axle housing.
In the second pic you see the rest of the brake tubing run to the left front wheel, but the "T" is hidden by the left engine mount.
« Last Edit: January 23, 2013, 01:50:44 AM by calvinhunt »
Offline BMIC
  • Weekend Mechanic
Re: Brake Question
« Reply #2 on: January 23, 2013, 04:58:04 AM »
Thanks Calvin, that is exactly what I needed to know and as always great work.
