Author Topic: Carter WO carburetor  (Read 1279 times)
Offline Stearman817
  • CJ3A
« on: December 24, 2012, 11:06:40 AM »
Diagnostic help needed:  my 49 CJ3A with Carter WO carburetor seems to be "cutting out" or "hesitating" and will no longer idle, but will remain running with some pedal in and higher RPM.  It's not a regular, or repeatable "cut out", and does not seem to be "bumping around" related. The engine starts cutting out, then dies most times, but starts right back up.  Carb was a 2007 overhaul by Kaiser Willy's.
Ignition is working fine, with no voltage drop out to any plugs of any type, so I am thinking this is a carb issue. The fuel is clean, fresh and running well in other machines.
What I have done so far is to inspect the fuel intake screen on top of the float bowl where fule line intakes, and it is clean and unobstructed.  I have noticed a higher fuel level in the top of the glass bowl above the fuel pump than usual.
Any experienced advise would be appreciated.
Stearman817
CJ3A
Re: Carter WO carburetor
« Reply #1 on: December 24, 2012, 11:45:22 AM »
Pull the idle jet out and clean it. My '49 periodically needs to have it cleaned. Then its fine after that.
Offline Stearman817
  • CJ3A
« Reply #2 on: December 24, 2012, 06:36:09 PM »
Thank you Garage nome.  And Merry Christmas!
Stearman817
CJ3A
