Author Topic: Engine ID  (Read 4764 times)
Engine ID
« on: November 14, 2012, 07:47:35 AM »
I've been going back and forth with BMIC about the history of my motor and figured it was time to bring it to the Council of Jeep Wizards.
According to the story I got from the PO, my current motor was purchased "new in a crate" from some place in NY shortly after the original motor blew up circa 1990. It was decided that dropping in a NOS motor was easier and less expensive than rebuilding the original one, so that's what they did. I did some research on the engine number awhile back and it does appear my motor was designated as a replacement engine. It was painted red, not black, and I believe the numbers indicate such. The number on the block is "908756" and there is no number at all on the water pump boss. Is this a designated replacement motor? Were they produced for both Jeep and generator replacement or would they have been different? Were new motors still around back in the early '90's? I also have reason to believe that the engine mounting plate that came with this motor had both flanges facing the same direction, not opposed like they are now.
I find it a little surprising that an untouched NOS motor could still be found, even 20 years ago, but that's the story I got. Bubba can be a good story teller though. Who knows. Any input?
Re: Engine ID
« Reply #1 on: November 14, 2012, 11:19:22 AM »
Judging by the appearance of the bolt on parts, I would bet it was a short block that was installed using the original head, front plate, manifolds, etc.   Is the number you mention the casting number ?
If you can, post a pic of the back and the right side as well, and the head, so the experts have all they need to make a postive ID. THE block looks liek the later block by the webbing I see at the back.
As far as whether NOS engines were available in the 90's stranger things have happened. MB engines new in the crate pop up from time to time , even today.. Don't forget that Sears and JC Whitney also were selling replacement rebuilt engines at one time, too.
Is that faded red paint or red oxide primer on the block?
Re: Engine ID
« Reply #2 on: November 14, 2012, 04:07:44 PM »
More photos here. The casting number (the number on the bottom right side of the block?) is "18" followed by a clock-type character pointing to roughly the "11 o'clock" position followed by "908756". I'm not sure if that is red paint or primer. I have since painted everything black.
I have also included a pic of the original motor, which now belongs to BMIC and has been beautifully rebuilt.
Re: Engine ID
« Reply #3 on: November 14, 2012, 08:11:43 PM »
L head engines with casting number 908756 appeared in the late 50's. These would have been factory installed in DJ-3As and available for use in stationary power equipment as well as new replacement engines from a Willys dealer. As far as I know all the engines had serial numbers stamped on them.
Did you dismantle your current engine? What was the bore and crankshaft diameters?
Re: Engine ID
« Reply #4 on: November 14, 2012, 08:37:42 PM »
Thanks for the info, Bob. I was hoping you would chime in. I have not dismantled this engine and with a little luck I won't have to for awhile. The serial number is the one stamped on the water pump boss, right? Mine has nothing there.
Re: Engine ID
« Reply #5 on: November 14, 2012, 08:46:07 PM »
Yes, the serial number should be stamped on the boss by the water pump. The lack of a serial number makes me think it was a rebuilt engine that had been decked. Any one of a dozen or more companies were rebuilding Jeep engines.
Re: Engine ID
« Reply #6 on: November 14, 2012, 09:26:32 PM »
So pretty much the only way to tell for certain whether or not it's a rebuilt motor vs a new one would be to open it up and start measuring. None of this really matters to me other than trying to determine the history for the sheer sake of curiosity....and I'm not curious enough to go tearing into the engine unless it really has problems. That day will inevitably arrive, though, so I might as well have a checklist of items to look for. Thanks again.
« Last Edit: November 14, 2012, 09:42:36 PM by Ryan_M »
Offline BMIC
  • Weekend Mechanic
Re: Engine ID
« Reply #7 on: November 15, 2012, 07:12:33 AM »
Was there a specific Jeep or industrial application that used a mounting plate with motor mount flanges going in the same direction?
Re: Engine ID
« Reply #8 on: November 15, 2012, 08:56:33 AM »
BMIC,
The CJ2A has the motor mount flanges that both point toward the rear.  This is the easiest way to determine whether the frame....and engine...were from a 2A or a 3A.
Offline BMIC
  • Weekend Mechanic
Re: Engine ID
« Reply #9 on: November 16, 2012, 07:29:31 AM »
Thanks Tim, sometimes it's as simple as that. I know the engine mounting plate issue (and flange direction) has been has been the subject thread many times previous.
Ryan I guess without a water pump boss identification number the history of your current engine can only be traced with clues. Too bad any engine rebuilder would remove that ID for any reason, it is key to what you have.
Another interesting ID issue. Once I had the block Ryan gave me hot dipped and cleaned I photographed 16 seperate ID numbers, symbols, and letters both forged and stamped. I'm not sure how helpful but certianly interesting to identify what all those mean.
