Author Topic: gas line orientation  (Read 1570 times)
Offline Shalka04
« on: September 28, 2012, 04:43:44 AM »
So the other day, I was under my jeep putting things in place and became convinced that I had routed the Walcks Prebent fuel line in the wrong way. �So I sorked it out of the rig and took a closer look. �Now I'm not sure which end should match up with the bottom of the fuel tank. �I can almost see a route or justification for either way, WITH a little further bending or twisting.
Any clues on the right way that it should be oriented?
Thanks
-John
« Last Edit: September 28, 2012, 04:46:34 AM by Shalka04 »
Offline p3ferris
Re: gas line orientation
« Reply #1 on: September 28, 2012, 07:46:41 AM »
On my 2a it comes out of the tank straight down.   so my estimation is the left of the pic goes to the tank as it has a 90 deg.angle.
« Reply #2 on: September 28, 2012, 07:18:43 PM »
Here is some fuel line info...
http://www.cj3a.info/tech/line.html
