Author Topic: Carter WO Carb /Metering Rod Gauge's Available  (Read 2957 times)
Offline Kendog
« on: September 20, 2012, 05:40:32 PM »
Hi all. I recently manufactured a short run of brass Metering Rod Gauges for properly setting up your Carter WO carburetors.
They are all with Carl at Walck's 4WD, so please contact them at 610-852-3110 for pricing and available inventory.
I hope this is not a violation of this board, and helps many of you, thank you. Ken
Re: Carter WO Carb /Metering Rod Gauge's Available
« Reply #1 on: September 20, 2012, 05:44:46 PM »
Do they come with instructions for the adjustment?
Offline Kendog
« Reply #2 on: September 20, 2012, 05:59:13 PM »
No Gunslinger, however carb rebuild instruction is easily found on the web for setting your metering rod height, but new carb kits do not have this tool any longer. This takes the guesswork out of a critical setting.
