Author Topic: Rear Differential fluid leak question  (Read 1510 times)
Offline 3aJeeper
  • Luvs me a flatfender Jeep!
« on: September 16, 2012, 03:41:57 PM »
Working the rear end of the jeep. Did the brakes including a new outer axle seals. I opened the differential to inspect/clean/change fluid. All the gears looked pretty good so I drained the old fluid, cleaned it out and replaced the fluid.
Decided on new leaf springs so I supported the axle while I dealt with new springs. I didn't have the axle supported exactly horizontally - one side a little higher that the other. At some point - couple days maybe?? - I noticed that there is some fluid from the differential that leaked out of the lower side of the axle. It took me a while to spot it as I covered the previous brake work I had done with plastic bags to protect it from dust from some grinding I was also doing. The fluid had collected in the bag.
How big a problem is this?
« Last Edit: September 16, 2012, 03:42:40 PM by JBCarney »
1951 CJ3a
F-134 Hurricane engine
Re: Rear Differential fluid leak question
« Reply #1 on: September 16, 2012, 07:23:37 PM »
JB,
There is an inner axle seal also.  Could be the reason you have a leak.  I'm not sure how difficult it is to get to.  I didn't need to replace it on mine.
