Author Topic: t90 rebuild synchronizer/hub question  (Read 1154 times)
Offline NoCoWillys
« on: August 04, 2012, 09:59:53 PM »
So I just finished my rebuild, I think, but the synchronizer/hub between 2nd and 3rd is really stiff.  It will slide, but only with some encouragement.  Without the springs and plates, it has a real nice fit.  This is the old one since I didn't really see that much wear on it.  I think it had been replaced at some point. Now I haven't tried with the stick yet,  could it just be it's that stiff with all the brand new springs and everything around it?  The 3 holes are lined up for the plates to go into.
'53 CJ3a
Re: t90 rebuild synchronizer/hub question
« Reply #1 on: August 04, 2012, 11:22:53 PM »
It's normal to be hard to move by hand with it assembled in the tranny or even in your hand. I wouldn't be to concerned as long as it moves completely into each gear. Try putting the shift tower on temporarily and shifting it through the gears and that should tell you what you want to know. Be sure to squirt some oil on the synchro assy before you do the shift test.
