Author Topic: Rear Axle Yoke Problem  (Read 5172 times)
Offline BMIC
  • Weekend Mechanic
« on: July 30, 2012, 10:13:31 AM »
I just replaced the Pinion Shaft Oil Seal on my Dana 44, cleaned and put anti-seize on the yoke spine's. put the yoke back on the shaft, the washer and the pinion nut. Everything is tight and turns freely until I tighten down the pinion shaft nut, then it all binds up.
What am I missing here? :exclamation
Re: Rear Axle Yoke Problem
« Reply #1 on: July 30, 2012, 02:26:53 PM »
Is the axle housing out of the Jeep? Did you just disassemble the differential or just pull the yoke off without pulling the ring gear and pinion out of the housing?
Offline BMIC
  • Weekend Mechanic
« Reply #2 on: July 30, 2012, 03:11:53 PM »
Hi Carl,
 I just replaced the pinion shaft oil seal, no work was needed on the gears or shaft. I did need a puller to remove the yoke. It seems like the yoke is binding against the pinion shaft berrings when the nut is tightened. The newer seal from KW was slightly different than the old one but is seated well and does not appear to be an issue.
« Reply #3 on: July 30, 2012, 05:42:44 PM »
I am not an authority on the axles but I am replacing the pinion seals on the front and rear on my Jeep. I had a very hard time getting the yokes off and they are still tight going back on. I made a puller just like one shown on the CJ2 site in case I have to pull them off again. I bought seals from Walcks that look exactly like the original seals and today I got the wear sleeves for the yokes and put them on. I am making a tool to pull the yoke on the pinion shaft rather than pound it on.
Now to your issue, the pinion bearings have shims and a spacer to set the bearing preload according to the parts book and there is no way for the pinion to lock up if you only pull the yoke and put it back on. I think the seal is sticking out to far and rubbing against the yoke. If you have torqued the yoke nut to about 100 ft lb or tightened it with an impact wrench and it seems to be locked up I would pull it again and look real good at the seal to see if it is deformed.
« Reply #4 on: July 30, 2012, 05:49:16 PM »
How different is the seal? Are you sure the dustshield on the yoke isn't binding against the seal? That's a fairly common problem with some "universal" replacement seals. They're made for yokes without a shield and can bind if the yoke has one.
Does it look like this?
Offline BMIC
  • Weekend Mechanic
« Reply #5 on: July 31, 2012, 07:44:24 AM »
The dust shield on the yoke is something I will have to recheck. I did remove it from the yoke to straighten and paint it but I thought that I had correctly reseated it, that is a possibility....
Yes, the seal Larry has posted is the replacement I used.
I will take a better look at the dust sheild clearance issue, that seem to be the most likely answer.
As alway's thanks ...
« Reply #6 on: August 01, 2012, 03:05:40 PM »
The small gasket pictured above goes in first and then the seal gets seated against the gasket. If it isn't seated fully the yoke could bind against it. That's another possibility. Aren't Jeeps fun? �:)
« Reply #7 on: August 01, 2012, 11:34:12 PM »
Also, the raised area on the seal in the photo goes toward the inside of the differential. If you put that to the outside that may lock the yoke up.
Offline BMIC
  • Weekend Mechanic
« Reply #8 on: August 02, 2012, 06:17:10 AM »
Jeez...... I am embarrassed to respond to this.
Larry, the gasket is sitting neatly on top of the frame next to the axle. I put it there so that I would not forget it.
Carl, the raised part of the seal is facing out towards the yoke and I'm sure binding on the yoke dust cover.
KW.....order please!
Yours truly,
Bubba
« Reply #9 on: August 02, 2012, 07:12:03 AM »
 ;D You'll never know how close I came to putting both of mine in backwards. I am replacing both the seals now and am making some tools to do the job.
« Reply #10 on: August 02, 2012, 08:50:30 PM »
Yours truly,
Bubba
This is outstanding. I have been embarrassed to reply to more than one of my own posts. Thanks for making my night.
« Last Edit: August 02, 2012, 08:50:56 PM by Ryan_M »
Offline BMIC
  • Weekend Mechanic
« Reply #11 on: August 03, 2012, 07:51:39 AM »
Hey Ryan,
 42 years of marriage has blessed me with a strong sense of humility and the ability to admit my mistakes. Now for a little bending of the truth, how many fish did you catch at Pemiquid last week?
« Reply #12 on: August 03, 2012, 06:48:34 PM »
Hey Ryan,
The only thing that could have topped it would be if the gasket was visible lying somewhere in the background of the pic you posted.
And since you asked, yes, quite a few mackerel found their way from the sea to the grill last week. It's the "one that got away" that was a monster. Must have been 100lbs or better...lol.
