Author Topic: T18 Output Shaft Bushing  (Read 1712 times)
« on: July 25, 2012, 11:49:05 AM »
I have removed the brass bushing from the output shat and was wondering if there is a specified depth for the new bushing. My plan is just to press it in as deep as the one I took out. Just wondering.....
Tumbleweed...........
Re: T18 Output Shaft Bushing
« Reply #1 on: July 25, 2012, 12:06:18 PM »
I would put it as deep as the one you removed. Also, be sure to put the shaft that fits into the bushing in it to be sure it doesn't need to be reamed out.
« Reply #2 on: July 25, 2012, 02:59:13 PM »
That is what I figured. Can't go wrong if you put it in like you took it out unless it was broken to begin with!
I think the ID of the bushing is .625 / .627. I'll do some checking on the mating shaft to see if mine is worn too much. Not sure what that dimension should be.
Thanks.......
