Author Topic: Rear main seal question  (Read 1873 times)
« on: July 24, 2012, 10:35:50 AM »
I have a FelPro gasket set and it has the two round rubber pieces that fit in the holes on each side of the rear main cap. The question is FelPro instructions say to fill the two holes with RTV and don't mention using the two rubber pieces. Has anyone filled the holes with RTV and NOT used the rubber plugs per the FelPro instructions?
 Willys says to cut them off 1/4" long and put them in.
I thought about that a while and decided to coat the rubber shafts and coat the hole bore and put them in and leave them 1/4" high. I spun them around as I pushed them in the holes to spread the RTV around. When I put the gasket and pan on it pushed the plugs down an expanded them some to help seal like it's supposed to.
Re: Rear main seal question
« Reply #1 on: July 24, 2012, 05:24:33 PM »
Can't say why they don't want you to use RTV, I did not and have had no problem...
« Reply #2 on: July 24, 2012, 10:12:26 PM »
FelPro put the rubber plugs in the set but in the instructions they said to fill the two holes with RTV and not use the plugs. It's odd that they would say that and put the plugs in the set. OTOH, the kit wasn't supposed to have the rope seal in it but it did but it didn't have the rubber mains shaft seal.
Offline Redrockman
« Reply #3 on: July 24, 2012, 11:05:20 PM »
I lost a motor due to silicone/RTV getting into oil passages and clogging oil feed lines, so you may want to check if the RTV made it into the bearings or the internal side of the engine.
The oil pump was contaminated by bits of RTV that got into the "relief" side of the pump and i'm sure it would have caused issues......
Better safe than sorry,
My 2cts worth.
Redrockman
« Reply #4 on: July 25, 2012, 12:03:56 PM »
Yes, I was extremely careful about a very thin film in any area that extra RTV could enter the lube system. In fact, I pulled the oil pickup assembly off after bolting it down to be sure none squeezed out into the oil passage and it was just fine.
I learned a long time ago a little bit will do the job.
