Author Topic: Drawing for a valve driver tool if you need one  (Read 954 times)
« on: July 23, 2012, 04:36:17 PM »
I made the tool out of 1045 CR. That's a carbon steel that can be slightly hardened if you wish. The small bushing is made of tool steel and you can use air hardening or oil hardening but I didn't harden it and it works just fine. If your going to use this tool in a shop with a lot of use then harden all the pieces. The fractional sizes are common stock sizes but the dimensions in decimals have to be +/-.001" for everything to work right. If you have any questions post or PM them. If you want a copy of the drawing I can send it in jpeg, tiff or pdf by email.
EDIT: when I designed this tool I made it to only be used a few times and that is why I used cold roll. The shoulder that drives the guide in was flaring and on the 5th guide it broke the guide. That's when I modified the tool and used a tool steel sleeve. If you make the tool it can be redesigned for long term use by making the long shaft part out of tool steel and hardening it. Then you wouldn't need the small sleeve. The large collar is so you only need one long stem part. The guides are set 1" deep on the exhaust and 1 5/16" for the intake and that is what the collar does. I felt like you could be off 1/32" +/- on the depth and it wouldn't hurt so some of the dimensions allow for that. If you stack up the dimensions it may not be exactly 1.000" and 1.312".
This is what it looks like when you use it. When the large bushing is one direction it works for the intake guides. flip it and it works for the exh guides.
« Last Edit: July 24, 2012, 08:47:21 AM by Carlsjeep »
