Author Topic: head mounting Studs -VS- Bolts  (Read 1429 times)
Offline Shalka04
« on: June 24, 2012, 06:36:29 PM »
I wanted to see if there were any thoughts or experience replacing studs with bolts?  If it's not an issue other then paying attention to their elngth, can I get away with off the shelf grade 8 bolts or do I need some weird heat treatment item.
Regards,
-John
Re: head mounting Studs -VS- Bolts
« Reply #1 on: June 24, 2012, 08:40:53 PM »
The bolts have to be sealed at the threads so you will have to put sealer on the thread. Since the threads in the block are coarse and the thread on the stud for the nuts are fine there is an issue there. When you put the stud in the block and snug it some then the torquing force is spread evenly over the length of the thread in the block. Cast iron is not real strong so torquing a bolt in the cast iron block may cause the thread to fail and strip.
These blocks are soft cast iron and I wouldn't trust using bolts in place of the studs. If you want to use bolts then a grade 8 bolt with hard washers is what you want.
« Last Edit: June 24, 2012, 08:42:19 PM by Carlsjeep »
Offline Bedrock
« Reply #2 on: June 27, 2012, 10:48:08 AM »
As Carl said, the threads in the block are coarse, so the use of bolts could change the torque specs as compared to studs, which have nuts torqued onto a fine thread  When I got my '51 3A it had bolts, and there had been a leaking problem.  I took off the head because I wanted to replace the bolts with studs, and there were cracks in the block radiating out from about 5 of the stud holes.  A couple of these cracks had opened up pretty well.  I don't know whether the use of bolts, and then over torqueing, caused the cracks.  Maybe the PO tried to stop the leaking by applying more torque to the bolts.  I ended up getting another block.
My suggestion is to use studs.  That is what was originally used, and I think when in doubt, it is generally safer go with how things were originally designed.
