Author Topic: steering assembly  (Read 4044 times)
Offline 49willyz
  • Jeep in a box
steering assembly
« on: June 07, 2012, 02:07:07 PM »
Can someone tell me if the MB column and box is interchangeable with a civilian 3a? I've acquired a military one but not sure if the turning radius is the same. Call me old fashioned but I just can't leave the Chevy Impala column and box in that came with it. �;)
Re: steering assembly
« Reply #1 on: June 07, 2012, 09:58:35 PM »
The turning radius is the same. The shaft is a different length, about 2 inches shorter than a CJ3A, and the horn wiring is different. The shorter shaft means the steering wheel will be farther away when driving.
Offline 49willyz
  • Jeep in a box
« Reply #2 on: June 07, 2012, 10:03:22 PM »
I was afraid of that. Thanks Larry. Anybody need a column, shaft, and box for their M-38? Anyone got the right set up they wanna part with?
« Reply #3 on: June 07, 2012, 10:58:12 PM »
Walcks might have what you need. It won't be listed on the website but give them a call.
http://walcks4wd.com/
« Reply #4 on: June 07, 2012, 11:43:21 PM »
Perhaps that would be a good swap for a, shall we say, largely proportioned driver around about the stomach area.
« Reply #5 on: June 08, 2012, 07:04:57 AM »
Girth challenged? �:)
« Reply #6 on: June 08, 2012, 09:54:04 AM »
Why the difference in length between the military and civilian jeeps?  Did GI's need more room for them with their gear on or where farmers just thinner back then? :-?
« Reply #7 on: June 08, 2012, 12:25:13 PM »
Mac,
I don't know for sure, but...
the rear wheel wells were larger...longer on the MB, GPW and 2A.  Could this push the seat further forward?  If so,
this would force the steering tube and shaft to be shorter.  All to maintain a little room between the driver and the wheel?
It probably would be a good mod in a 3A...for the more portly among us.
« Reply #8 on: June 08, 2012, 12:51:17 PM »
There were actually three different lengths.
Early CJ2A (same as MB) with horn brush contact      40.5"
Late CJ2A with horn wire out the bottom       � � � � � � 41.5"
CJ3A/M38                         � � � � � � � � � � � � � � � � � � �42.5"
Military jeeps were designed for easy access, not comfort, so the shaft was designed with that in mind. As civilian production evolved the shaft was lengthened (CJ2A). When the CJ3A/M38 came out the rear inner fender wells were shortened to allow the seat to be moved back for more leg room. The shaft was again lengthened accordingly.
Offline 49willyz
  • Jeep in a box
« Reply #9 on: June 08, 2012, 03:47:00 PM »
I can't wait to tell the little lady that I don't need to go on a diet, just need to install the wrong steering shaft! If that's seriously the only difference, all I'd need to do is wire it for the military horn button looks like I just bought myself some more... uh "leg room". Thanks guys
« Reply #10 on: June 08, 2012, 11:32:38 PM »
Get a photo of you behind the wheel with a 3A shaft and tube, swap into the MB tube, take another photo, show the wife the photo, proclaiming you lost all that weight.  "My dear wife...photos don't lie."
Offline 49willyz
  • Jeep in a box
« Reply #11 on: June 09, 2012, 12:37:03 AM »
You my friend missed your calling as a couples therapist!
