Author Topic: What engine paint ????  (Read 2801 times)
Offline turkehunt
« on: June 05, 2012, 05:33:37 PM »
 8-) Got my frame all rustproofed and painted Eastwood Rust encapsulator   / then Chassis Black   :-/ Now Im ready to paint the engine and start putting the body back on ! What paint do yall recommend / I would like to brush it on to avoid all the masking / overspray problem   Im thinking gray on engine block {it is orange now }with chrystler blue for transmission /transfer case / bellhousing & oil pan! Thanks in advance for replys   8-)
Re: What engine paint ????
« Reply #1 on: June 05, 2012, 06:02:30 PM »
Well, I'm partial to OD (olive drab)  See Avatar.
It's really a personal preference, but I think the gray block with the Crysler blue components would look pretty sharp! :o
Gray backround will make it easy to spot a leak...
Not saying you're going to leak, just sayin' it would be easier.
« Reply #2 on: June 05, 2012, 06:14:31 PM »
One tip for you...the 500 degree engine enamel is fine for the engine and head but if you intend to paint the exhaust manifold (and even the intake manifold) you have to use the 2000 degree stuff.  The 500 will burn off of the exhaust manifold immediately and parts of the intake manifold that are near it will discolor badly over time.  But they do look great painted.  One of the guys here from Belgium, I believe, went with a gray block with black components as I recall and it looked really good.
Offline turkehunt
« Reply #3 on: June 06, 2012, 06:34:00 AM »
Thanks for replys  ;D  What brush on paint would you recomend ??? POR15 deosnt offer gray !
« Reply #4 on: June 06, 2012, 12:16:52 PM »
Eastwood does have the Chevy gray. They may have others.
I brush coated mine with MasterCoat Silver primer. �(good to about 350 degrees at this heat for 15 straight days) �then top coated in regular OD emamel. �I don't know how well mine will hold up. �I have only been driving it for 7 months. �No current signs of paint failure. �
On my exhaust manifold, I spray painted it with Rustoleum super high heat. I think its 3000 degree. (Home Depot) There was a baking process to set this paint. �(Don't tell my wife what I used her oven for.) �I am not sure how long this paint will stay on the manifold, but so far, no signs of failure here either.
« Reply #5 on: June 06, 2012, 11:19:54 PM »
I sprayed my block with rattle can black ceramic engine paint, its cheap, durable, and easy to get.  I got it at NAPA, I did the head in the same ceramic red, and used a John Deere black exhaust paint on the manifold.  That one surprised me as to how durable it is, I've got 500 miles on it and its still really nice.  It did something I didn't expect, the exhaust side turned a flat black, but the intake stayed gloss black.  I think it looks kind of neat.
